20" tire options - Ford Powerstroke Diesel Forum
post #1 of 14 Old 02-05-2007, 06:26 AM Thread Starter
20" tire options
Hello Fellow Strokers!
I've got an 07 cc/sb F250 lariat with the factory 20" wheels. What are guys replacing the 275/65 Goodyear AT/S with?? I would like a little bigger meatier tire but I don't really know what to get. The specs on the factory tires are 34.1 tall and 11 wide. I was thinking a 35x12.50 would probably work nicely. Any thoughts??
bjc8201 is offline
post #2 of 14 Old 02-05-2007, 07:01 AM
If you try to go with a 35 you will need a small lift.
07 F250 King Ranch
Bone Stock with 123K
King Hardhead is offline
post #3 of 14 Old 02-05-2007, 07:17 AM Thread Starter
why? the factory tires are 34.1" tall and there is tons of clearance everywhere.
bjc8201 is offline
post #4 of 14 Old 02-06-2007, 07:07 PM
I have 35x13.50x20(aftermarket wheels) Cooper Discoverer STT's on mine. Stock height in the rear. 2" coil spacers in the front. No rubbing anywhere.
2006 F350 Lariat - 6.0, Torqshift, CC, shortbed, FX4 - 2" front leveling kit, 35x13.50's on 20's, MBRP 4" turbo back exhaust, ARP head studs, Elite Diesel "Sneaky" EGR delete pipe, Bulletproof Diesel EGR cooler, ZooDad mod, and an SCT X-CAL, Innovative Diesel tuned.
1989 Mustang LX - 5.0 with N2O
1963 Fairlane 500 - 5.0 with N2O
1997 Cherokee - 4" lift on 33's
MYSTICSVT is offline
post #5 of 14 Old 02-07-2007, 03:05 AM Thread Starter
that is one sweet rig!! How do you like those coopers?
bjc8201 is offline
post #6 of 14 Old 02-07-2007, 03:26 AM
I like them. I can't commment on the wear since they've only been on there for about 5K miles. But they look great and are pretty quiet for a mud tire. That picture is deceiving BTW. Even with the 2" coil spacers, the back end is still about 2" taller than the front.
post #7 of 14 Old 02-07-2007, 08:12 AM
Betaracer's Avatar
Quoted: 16 Post(s)
The stock tires are comparatively narrower than the aftermarket 35" tires for 20" rims. The rub is when turning and gets closer to the fender liner at the rear of the tire and the lower valance at the front of the tire since the edge of the tire is further away from the steering axis.
2016 F-350, FX4, CCLB, 6.7PSD, 7" OUO/ICON/FOX lift, 37x13.50-18 Toyo MT
Betaracer is offline
post #8 of 14 Old 02-07-2007, 09:04 AM Thread Starter
I just found out that BFG makes the All-Terrains in a 285/65/20 load range E! That should be a perfect replacement for the goodyears! Does anyone have these in this size?
bjc8201 is offline
post #9 of 14 Old 02-07-2007, 09:12 AM
2 Questions, Do you have a side pic with more light, and what wheels are you running (offset and width as well)?
Looks very nice!
07 F250 King Ranch
post #10 of 14 Old 02-07-2007, 05:46 PM
Looks very nice!
They are 20x9. Sorry, don't know the offset.
