6.0 - how many miles and problems or not
We are looking at getting a 2003 crew cab 6.0 automatic. It has 125,000 miles on it. We have never bought a diesel before. Wondering how many miles your's has and if you have had problems with it or if you have never had any problems with it. You hear a lot of people saying not to get them but wondering if it is talk or if it is backed up. Also do you need to do certain things to it to make it run better and what would my MPG be on it?
Thanks Dan |
welcome to the org. the 03 6.0's are hit or miss. i owned one before and only had to replace the turbo (under warranty) other than that, i love the 6.0's
I have 150K on mine, and I haven't had any major issues. The weak points of the motor would be the head bolts and EGR system.
I usually get 15-18 mpg's oh ya...Welcome to the addiction..err....I mean Org |
I have 91K on Mine and its in the shop being studded and EGR Delete only cuz i wanted too though if i drove this thing like normal without those custom tunes from Eric it might be a different story. i love mine, welcome
113k on my 03 icp replaced at 85k. All injectors replace between85 and 95k. About to do egr delete just I'm about to put an sct with cales tunes on it. Love it. Held up good even though I drive it like I stole all the time.
Thanks for the replies and welcomes. Not sure what some of the things are that you are talking about such as the EGR, Studded, SCT w/cales tunes, and ICP. Did you do these things because you wanted to or because you had to? I don't think much is different than factory on this pickup. Is that something that I should be worried about?
Thanks |
EGR(exhuast gas recirculation) the coolers crack on the inside and leak coolant into the engine and in extreme cases can hydrolock the engine. get rid of it your truck will thank you and run better and i think a little bit lower egts. Headstuds are one the top things you should consider specially if you are wanting to add power or do a lot of good size towing. the factory head bolts will stretch and lift the gaskets. check out sctflash.com. about 95% of the people on here are running it or plan on running it. it is the s*** to get for this truck. again your truck with thank you for it. better fuel economy(if you can keep your foot out of it). and better shifting. ICP(injection control pressure sensor) they go bad every now and then mine was replaced under warranty.
i had an 04 that i bought brand new that went problemm free until 80k+ miles. then too much went on it including the whole motor. problems were starting to come out of nowhere. egr, injectors, wire harness. had the motor replaced under warranty, but i got rid of it shortly after. sold it to a friend of some friends out in california in february of 2008, and i drove it all the way out there with no problems. he put on an egr delete, and from what i hear it's got over 130k now with minimal problems.
I have an 05 that had 62k when I bought it in Feb. It now has 73k and hasn;t missed a beat! and I get between 16~20 mpg depending on my right foot and the traffic
My family has had a total of 5 6.0's. The 03 100% stock had injectors at 2 months old and then 2 at 67K miles and then the top end rebuilt at 86K miles do to headgasktes blowing. The other 03 has 170K miles an on 4th engine. First engine lasted 97K miles. Reman engines are junk from the start. My 05 70K miles and blew the EGR cooler stock and then scored the engine when I tuned it. I'm on the 3rd engine. The 1st reman that came crapped out. The other 05 engine held up fine and was tuned and was sold with 88K miles. The 06 100% stock had the HPOP system rebuilt at 26K miles and then the engine was pulled at 36K miles for a bedplate leak and now has electrical issues. With no warranty 6.0's are a pricey engine.
