Which oil for my 2003 PSD 6.0L? - Ford Powerstroke Diesel Forum
post #1 of 25 Old 06-16-2009, 08:32 PM Thread Starter
I just bought a used 2003 Ford Excursion 6.0L PSD and love it.
My driving characteristics are; around the country side with stop and go but mostly with trips typically less than 20 miles (carrying all 6 of us in the car). On the longer distance side of things we'll travel 200 miles towing a small utility trailer with a weight of about 1000 Lbs. at speeds around 65 mph not more than 8 times per year.
I want to change the oil a few days from now.
After I drain the existing oil I'll be installing an Amsoil oil by-pass filtration system and then refilling with new oil- but which type and make?
At certain intervals I'll have oil analysis done.
Ford recommends 15w40 but there seems to be a lot debate as to which oil is the most economical and highest quality.
Synthetic oils seem to have a lot of fans....but that stuff does cost A LOT.
Dino oil.....a lot of folks like too.
Which would you recommend for my situation?
Thanks fellas.
PDA1 is offline
post #2 of 25 Old 06-16-2009, 08:40 PM
Quoted: 5 Post(s)
Motorcraft oil and filters
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 25 Old 06-16-2009, 08:47 PM
DunesRunner08's Avatar
amsoil by far... I have been looking into this a lot lately..... and I cant find anything that shows the numbers that amsoil does for protection and lubrication and viscosity break down...
if you want to run amsoil you need to run their cleaner right before you drain your oil though.... I am about to get setup as an amsoil dealer myself because of how much I am starting to believe in their stuff...
Amsoil will extend your oil changes so it really doesnt cost more, they actually warranty everything for 25k intervals, so you will save money that route, they lubricate better especially for towing and heavy traffic application, not to mention race applications... there is no better... I am a royal purple dealer right now and I am dropping their line to go with amsoil
Beware!!!! The King Has Returned
DunesRunner08 is offline
post #4 of 25 Old 06-17-2009, 10:39 PM
Serious looking bumpers
Ratatattat is offline
post #5 of 25 Old 06-17-2009, 10:44 PM
does that mean you want to order one? lol
post #6 of 25 Old 06-17-2009, 10:48 PM
03Powerstroker6.0's Avatar
motorcraft and a 12oz jug of Prolong engine treatment :thumb
03 F350 Lariat CC LB 4x4,
straight Pipe 4" exhaust 6" tip
3" front lift
5100's bilstiens
high idle mod
Sct Gearhead tuned,
EGR deleted
trans,fp, boost, egt, ect, eot gauges
vgt switch
2low Switch
Zoodad
315/75/16 baja claw
Custom trac bars
coolent filter
ccv mod
arp studs by me
afe stg 2
fuel bb mod
Hids
Smoked LED tails/3rd
Harley headlights
Smoked led tail lights
08 T gate
Upgraded banjo bolts
2 12" subs/6x8 infinity speakers
JD cool Gaurd II coolent
03Powerstroker6.0 is offline
post #7 of 25 Old 06-17-2009, 10:51 PM
do you guys running conventional realize that conventional can breakdown in one trip across town? meaning you no longer have an protection? synthetic is the only route to go.... and with amsoil, 25k mile oil change intervals... you cant beat that
post #8 of 25 Old 06-17-2009, 11:41 PM
hazard's Avatar
valvoline premium blue extreme full synthetic 5w-40 here...love it
Thanks,
Adam
2006 F-250 6.0L CCSB Lariat 4x4, ARP studs, SCT tunes by innovative diesel, Silverline 4" turbo back exhaust no cat no muffler! Upfitter switches w/high idle mod, Edge Insight monitor w/EGT probe, autometer fuel psi gauge, Zoodad mod with billet plate. Ford Updated fuel psi spring and banjos, RCD egr delete, Ford updated oil cooler and stc fitting, dieselsite cac boots and coolant filter.
1984 Mercedes Benz 300D Turbo Diesel, cold air intake.
"Run Hard, Dream Big"
hazard is offline
post #9 of 25 Old 06-17-2009, 11:48 PM
Redneck47441's Avatar
Quoted: 2 Post(s)
I highly recommend synthetic less problems over the couser of ownership but IMHO it doesn't have to be Amsoil. Do not and I repeat do not go more than 7,500 miles on an oil change especially with the majority of short trips you make moisture builds up in the system and if you do some research on this forum and some other places the 6.0 doesn't do so hot with extended oil change do to the HUEI injection system now on a common rail system yes but not on ours. I also highly recommend only using motorcraft fuel filters and oil filters. Do some checking before you try extended oil changes.
OLD 2006 F-350 CC LB
SCT Tunes Cale, DJ, Spartan & Innovative
bilstien 5100's
fox 2.0 dual steering stabilizer
2" Leveling Kit
35x13.00x18 Nitto A/T
Zoodad, Autometers PhantomII, PTO switch,
Harpoon, 18" XD Diesels
2010 Toyota Tundra
Rock Warrior
Redneck47441 is offline
post #10 of 25 Old 06-18-2009, 12:57 AM
oil change
I'm from Louisiana and its verry hot down here, I have been using Royal Purple from the begining, and go 10,000 miles between oil changes. Am I doing any damage to my truck by going that far. Travle mostly 50 mile trips to town in stop and go traffic, should I change my oil more frequently?
TGleason is offline
