new guy...2007 powerstroke? - Ford Powerstroke Diesel Forum
Old 06-09-2009, 10:00 AM
I am new to the diesel world and was looking to get a 2007 powerstroke when I get back from deployment. Is there anything I know about the truck before buying one. I plan on putting an edge attitude with juice, a small lift, turbo back exhaust, some kind of intake, egr delete kit, coolant filter, and change out the head studs. Any other info would be awesome! Thanks in advance.
v/r
formuladriver01.
Old 06-09-2009, 10:03 AM
I feel you should know they are way over powered and very addictive to drive!!!
And the women always want to ride.
If you can live with that, Get one!
On a serious note, Thanks for what you are doing on deployment!
Old 06-09-2009, 09:29 PM
Send a message via MSN to JWJR Send a message via Yahoo to JWJR
Thanks for you service. many people will steer you away from the edge since it does not make adjustments to the tranny. you should get a SCT with custom tunes. also the stock intake flows very well and will keep up with your planned mods. instead of getting an intake may i suggest getting gauges to keep the vitals of you truck in check.
Old 06-09-2009, 09:38 PM
The amount of women wanting to ride is inversely proportional to your ugliness, though. LOL For example, I have yet to find any women that want to ride in my truck.
Old 06-09-2009, 11:58 PM
I think that buying a '06 or '07 used 6.0L may be one of the best deals going right now. A lot of people have heard the horror stories and have traded them in. If you find a good price (which I have seen quite a few good deals) AND you have checked into the reputation of a local dealership on repairing the 6.0L - then GO FOR IT! So much depends on having a dealership that has competent techs to troubleshoot and work on any future problems.
If you are looking at used 6.0's here are a few considerations (along w/ the OASIS and CARFAX reports that are essential).
Some 6.0L weak points (things to check):
Look for signs of coolant degas bottle overflow (dry white residue on and around the degas bottle or no level in degas bottle).
Lots of idling can cause EGR problems. I look at the hours on the engine (if it has this monitored) and divide the miles by the hours (is it below 30? If so, may have had lots of idling).
Even without much extended idling EGR valves can plug quickly - maybe negotiate for a new EGR valve. In fact, I would negotiate for them to pull the EGR valve to inspect it (have them show it to you when it is out and then you need to look into the intake). Check for wetness (w/ rear end jacked up) and for excess soot. Wetness indicates an EGR cooler leak. If the valve is gunked up, have them replace the valve. If the intake is real bad, you may push them to clean it as well.
Look underneath for oil leaks - some trucks have had a lot of them.
If you buy from a dealership, I would negotiate for them to install the latest flash of all 3 processors (PCM, FICM, ECM).
Negotiating for an extended warranty is always a good thing as well.
Try to find out about the routine maintenance:
· Filter change intervals on time? What kind of oil (CI 4 + or CJ 4 - one of these is required)?
· OEM filters? Look at them and see what kind they are. Aftermarket filters can cause MAJOR problems.
· Find proof of Transmission being flushed/changed - it is recommended every 30,000 miles.
· Any exhaust problems visible (i.e. lots of white or blue smoke)? White smoke may mean an EGR cooler leak.
Check for any FLUID leaks (as stated previously - LOOK SPECIFICALLY FOR OIL LEAKS - 6.0L are prone to many of these from many possible places!!).
CEL (Check Engine Light) on? Consider getting a code reader and check for DTC's. You can have active DTC’s without a CEL.
The Electronic Shift on the Fly ESOF sometimes fails due to vacuum leaks. Be sure to check this out (several times in and out of 4WD and/or take front wheels off to inspect).
Check for excessive wheel bearing wear (looseness), sway bar (end link looseness), or ball joint looseness. Ball joints and sway bar end links tend to go out in the 70k-90k range. Jack one side up at a time and see if each wheel moves top to bottom only, if so, it is the ball joints. If it moves in all directions then probably wheel bearings.
Check the coolant - it should have the Motorcraft Gold Coolant - anything else and there may be problems. Look in the "degas" bottle and inspect the fluid - it should be gold colored and there should be NO OIL visible (oil emulsified in water can show up as brown sludge). As previously stated, the degas bottle should not have white residue around the sides of it (possible overheating issues).
Any evidence of a tuner ( aftermarket air filter, gauges, etc)? Tuners may or may not be bad. Some tuners are MURDER on the transmission. Some dealerships will cause you a lot of problems w/ them - even if you bought it that way used.
Aftermarket air systems could be a problem. Many of them (like K&N) do not filter as well and could cause issues. Up to 500 hp, the stock air system is best!
Try to find out if the original owner ever ran it empty on fuel or have plugged filters (fuel pressure below 45 psig can damage injectors)?
Then the common stuff I'm sure you know:
· Look at and smell the fluids. Make sure fluids not burnt, not too thick or dirty.
· Check the tires - abnormal wear?
· How do the brakes look? Any pads need replacement? Are the rear brakes excessively worn?
· All electronics working? Especially the AC (repair can be expensive)?
· Dents? Air bag been replaced, etc.
· See if he has any repair or maintenance records.
· Take off the price for windshield dings, paint chipped, torn upholstery, etc.
· Does the truck look too clean? Does it look like the oil was just changed? May be hiding something.
· Any extras - tool boxes, bumpers, etc.?
· Drive it - does it hesitate, stutter, or surge? Does it blow white or black smoke? When driving, brake fairly hard - note any pulls, pops, clunks, rattles, etc. How does it accelerate? You should romp on it pretty good. Drive in reverse and then back and forth - listen for clunks.
Oh - did I mention - when you find a truck you are interested in - get an OASIS report?
Add or subtract value based on condition, high miles, and presence of extras.
Old 06-10-2009, 04:29 AM
Thanks for all the great info everyone! I am going to print this out and go down the list when looking at a truck.
Old 06-10-2009, 04:31 AM
Thanks for what your doing and everything you plan on doing to your truck looks good
Old 06-10-2009, 04:32 AM
wriott
Guest
Posts: n/a
i agree with the above, and Welcome to the ORG
Old 06-10-2009, 05:53 AM
Hey, I'm plenty old and ugly but never have any truble findin women to ride with me. One pix was even censored from the org cause she don't care all that much for clothes. Yep, aint nuttin better than a good loyal truck, a cold beer and a fast woman.....hummm.. did i get that right?
