Welded EGR - Ford Powerstroke Diesel Forum
Old 06-08-2009, 04:20 PM
Welded EGR
Ok, I have heard of people welding their egr but what are the welding? Their valve or what...??
Old 06-08-2009, 04:35 PM
It's a cheap, (better than nothing) approacch to an EGR delete. They are welding the up-pipe so exhaust gas won't recirculate but you still have cooland running throught the EGR cooler, which can/will still fail. Talk to Abrannan19 at FCDP about their Full EGR Delete. With this setup you will never have a EGR worry again.
Old 06-08-2009, 05:09 PM
so its the same thing as the block off method
Old 06-09-2009, 12:30 PM
Old 06-09-2009, 12:38 PM
Lt. Negativity
Yes to an extent, my up pipe is welded up, I did mine long ago before Adam had kits or anyone else. Most where still getting kits together so I kinda did my own thing with a buddies' help
Old 06-10-2009, 10:22 AM
I stuck a freeze plug in my up pipe and also welded the egr valve itself shut so it cant be blown open from boost.
Old 06-10-2009, 11:10 AM
That's what I am talking about. Welding the actual valve not the pipes
Old 06-10-2009, 03:10 PM
