Temps Question. - Ford Powerstroke Diesel Forum
Old 06-07-2009, 08:44 PM
Temps Question.
Ok im just wanting to see what yalls oil and coolant temps are looking like with normal driving.
mine 70mph normal driving on flat roads.
oil 207-210
coolant 198-202
does this sound normal??? the temps have been going up ever since i have a blown egr cooler fixed under warranty. I there anything i should be worried about??
Old 06-08-2009, 07:42 AM
yea those r normals. im usually chillin at 190-200 for ECT, around 200 for EOT.
i have an elite diesel sneaky up-pipe with a block off plate between up-pipe and EGR cooler so my coolant will prob be a little cooler than yours.
Old 06-08-2009, 08:16 AM
Send a message via AIM to Sins4u33
sounds about right sir.
Old 06-08-2009, 09:41 AM
Ok but that dosent explain why the temp have been rising....before the egr cooler blew both temps were running well under 200 and now the just keep climbing up there. And when i tow i can easily see the the oil temp hit 230.....is this normal or is somthing going wrong?
Old 06-08-2009, 10:29 AM
maybe your oil cooler is pluged or plugging....just a guess though.
Old 06-08-2009, 11:10 AM
Normal driving:
ECT= 190*- 198*
EOT= mid 190's
Towing 8k from Cali to Denver:
ECT= 196*- 208*
EOT= 200*- 220*
Old 06-08-2009, 11:15 AM
Did you replace your oil cooler with the egr cooler?
Old 06-08-2009, 01:54 PM
I just looked at the warranty ticket and no they didnt replace the oil cooler....should this have been replaced?
Old 06-08-2009, 01:57 PM
It should have. This could be your problem. I know you are in Texas and it is probably a little hotter over there but, it is still hot here in Alabama and I usually see a oil temp of 180-200 and a coolant temp of 170-190 and thats not babying it.
Old 06-08-2009, 02:04 PM
well im taking the truck to them in the morning.....maybe everything will get straightened out.
