is this normal? - Ford Powerstroke Diesel Forum
Old 02-01-2007, 03:36 AM
is this normal?
It got pretty cold for a few mornings and my batteries did not like it so I had to change them both out but while doing so, I noticed both my inter cooler boots had black oily grease on them. is this normal? I pulled the codes and the only one on there was for low voltage due to the batteries getting weak.
They seem to be intact, I don't see any cracks or rips and are on tight.????
I'm at about 51,000 miles now on an 06 6.0
Thanks for any input
Scott
Old 02-01-2007, 03:57 AM
ADMIN AND TECH
very normal for there to be oil seep at intercooler tubes , if it gets real bad , may want to replace them ,they also can split if gets bad enough ,but oily film is normal
Old 02-01-2007, 08:07 AM
Scott W
once again thanks for your expertise. Very nice rides Scott, are any of those Fords yours, or just ones you've worked on?
Scott P
Old 02-01-2007, 09:06 AM
ADMIN AND TECH
the blue one is mine ,i get tired of one way and ill change up for awhile , which other trucks were you referring to ,the ones i my garage?
Old 02-01-2007, 09:09 AM
F-250's
yes in your garage.
Scott
Old 02-01-2007, 09:27 AM
ADMIN AND TECH
yeah i work at the ford dealer but also ,run a small independant shop called (trucks unlimited )and we do alot of aftermarket lifts ,performance ,etc.
