upgrade fuel pressure spring? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-04-2009, 04:09 PM Thread Starter
jnall63's Avatar
i just saw an ad for an upgraded fuel pressure spring claiming upgrade fuel pressure and in turn gives a little more power. anybody ever done it? is it worth it, spring is only $20
jnall63 is offline
post #2 of 7 Old 06-04-2009, 04:11 PM
Quoted: 5 Post(s)
sounds like the fpr shim mod to me.......people on here get mixed results from it, but no real power from it i think.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #3 of 7 Old 06-04-2009, 07:12 PM Thread Starter
jnall63's Avatar
well i was looking at egr deletes and came across it at gillettdiesel.com, i had never heard of it before
jnall63 is offline
post #4 of 7 Old 06-04-2009, 07:25 PM
npccpartsman's Avatar
Quoted: 5 Post(s)
You can get a BB or a part # 6592105 steel ball from a Bobcat Dealer for 10 cents that will do the same thing and put you at the perfect fuel pressure FWIW (which is not much). It's a pretty useless mod actually and remember........raising your fuel pressure does NOT insure that your are getting more flow from your pump. You could actually be getting LESS fuel by raising the pressure.
I Bleed Razorback Red
Ford Makes It, International Shakes It, Casserly Fuels It, KC Turbo Spools It, SCT Tunes It, and Trucks Unlimited keeps her Rockin the Road
npccpartsman is offline
post #5 of 7 Old 06-05-2009, 08:08 AM
fordfan30's Avatar
exactly, it does nothing for volume just pressure
06 F250 4x4 ecsb, lowered 2", 6 Autometer Phantom 2 guages, Accufab Elbow, Zoodad, Airaid , Magnaflow 4"dp, 5" pipe 7" short stack, Studs, Egr delete, sneaky pipe, regulated fuel return, 6.4 banjo bolts, Moderate FICM from Innovative, High idle and foglight mods, Bilsteins, Sulastic shackles, DIY Harley headlights and traction bars. 8.76 in the 1/8th
fordfan30 is offline
post #6 of 7 Old 06-29-2009, 06:37 PM
jerzydiver's Avatar
I tried it and the spring put the presure @ over 95 psi which is way to high so I would say its not good as the spring is way to stiff.
06 F350 XLT Crew Cab LWB FX4, power Captain Chairs / Snow Plow Packsage camper package / tow command / Amsoil oil bypass filter/ Billet Badges / A Pillar Quad gauges / overhead quad gauges / ExtremeAir compressor / Trian Air Horns / FX4 package / High Idle/Aux switch mod / Go Rino Push Bar / Go Rhino Rear hitch step / Hella Black Magic Driving Lights / Rhino Lining bed liner.
jerzydiver is offline
post #7 of 7 Old 06-29-2009, 06:50 PM
i ran into that a few months ago and thought about it but didnt know anything about it but atleast someone asked now i know
TommyBoy#1 is offline
