Went to Ford... - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-04-2009, 11:11 AM Thread Starter
Unhappy Went to Ford...
Well I ended up taking my truck to Ford for a transmission leak and state inspection. Well then the tech called me and says that they fixed the leak and inspection. He also said the lower ball joints are shot and the upper ball joints will need replaced. Then he said it would need an alignment too. Well all said and done its going to cost me "only $1040" as he said
03-blue-Powerstroke is offline
post #2 of 12 Old 06-04-2009, 11:13 AM
Firemanbill's Avatar
ONLY!!!
2004 6.0L Automatic F-250 XLT Lariat Crew Cab short bed 2wd. Reese Signature Series 16k 5th wheel hitch. Airlift Loadlifter 5000 airbags with onboard compressor.
Firemanbill is offline
post #3 of 12 Old 06-04-2009, 11:14 AM
45_ACP's Avatar
do the ball joints yourself they are easy! then get it aligned somewhere else for cheaper
Early 99 F-250
4x4_____________________________PCT Welding and Fabrication Engineering
6-Speed
Gauges: Boost, Pyro, Hour
DIY intake
DIY Straight 4" exhaust
HPOX line
ITP diesel over boost inhaler
PHP Phoenix- stock, 80hp DD, 100hp Performance, 65hp Moderate Tow, SmokeShow, Anti-Theft
Leveling shackels
45_ACP is offline
post #4 of 12 Old 06-04-2009, 11:16 AM Thread Starter
He said it would be 1200 but he felt bad because of the load of bs I told him about me not working much so he put it down to 1040 .
post #5 of 12 Old 06-04-2009, 12:02 PM
BLACK_PSTROKE's Avatar
id take it to a good alignment shop to get the whole thing done. if you dont want to do the ball joints yourself.. that price is a little steep IMO..
09 F250 FX4
2n006 F-350 fx4 lariat
cc. 6 sp. man. SOLD..........
MEMBER $5.00 gallon club
NRA member
BLACK_PSTROKE is offline
post #6 of 12 Old 06-04-2009, 12:11 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
how much does an avarage ball joint replacement cost? and how hard is it to do it your self? my driver side is bad.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #7 of 12 Old 06-04-2009, 12:14 PM Thread Starter
Im not sure but I think its cheaper that $1000
post #8 of 12 Old 06-04-2009, 12:33 PM
45_ACP's Avatar
the first time i ever changed ball joints it took me from 8am to 1pm and that was goofing off a lot and a trip to the auto parts store for a ball joint tool. basicly you take the wheel off and then the caliper then the caliper braket then your rotor then your locking hub then the actual hub with the 4 bolts on the back pull your axle out. all thats left you just have to unbolt the ball joints and bang them out of the axle and you get the steering nuckel then use the ball joint press and press the old ones out and then press the new ones in and re assemble.
Early 99 F-250
6-Speed
DIY intake
HPOX line
Leveling shackels
45_ACP is offline
post #9 of 12 Old 06-04-2009, 12:49 PM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
so you do em all at once?
Sold
LSP Group Threads
Jarrod B is offline
post #10 of 12 Old 06-04-2009, 06:09 PM
GS247's Avatar
yes do them all at once. you have the hub off you might as well. book time on it is just over 7 hrs i believe. i just had all of mine done, but i didnt pay that much it help that i work for a dealer and get employee cost.
03 EB EXcursion 6.0L
AFE intake
Edge Juice W/Attitude (gauges only)
Glow Shift Fuel, Coolant, & Trans temp gauges
w/ xtreme street from Innovative
FICM Hercules tune by PHP
MBRP 4" turbo back
Zoodad Mod
Fog light Mod with 9005 bulbs
ARP studs
Jefferson State Diesel Coolant Filtration System
FICM modded by Jefferson State Diesel 54.4V
Mag-Hytec trans pan (thanks Maddenjr)
GS247 is offline
