Changing a fan belt on a 6.0 - Ford Powerstroke Diesel Forum
Old 06-03-2009, 01:24 PM
Location: Savannah, Tenn. (over 100 miles east of Memphis)
Ok, I had to put a fan belt on a 06 6.0 today. I never in my life would of figure how much of b***h it was going to be. I had to remove all that plastic that was around the fan to get it off. What happened to the good old days when putting a belt on was only like a 15 minute job. Oh well, I was just curious if anyone else had as much trouble with this as I did?
Old 06-03-2009, 01:25 PM
lifetime member
get rid of the extra plastic. it runs fine without it.
Old 06-03-2009, 06:27 PM
i had a problem when my alt went out a few weeks ago, what a PITA
has anyone converted to electric fans? i see them for the dodge and chevy but not the ford. am i just missing them?
Old 06-03-2009, 06:45 PM
Flex-a-lite has a kit for electric fans, I saw the ad for it a while ago I think on here
Old 06-04-2009, 05:13 AM
Sounds like I need to get some eletric fans.
Old 06-04-2009, 05:25 AM
I don't know nuttin....
i have to replace my serpentine belt soon - 115k miles on it - and have been dreading it.
How long did it take to get that shroud off?
Old 06-04-2009, 06:38 AM
Send a message via AIM to Farmerjohn Send a message via Yahoo to Farmerjohn
I Think it would be more fun to pull wisdom teeth that to change one, Ive done 3 of them and I havent found an easy way yet
Old 06-04-2009, 06:44 AM
changing that belt can be the biggest pita. i never had such a hard time changing a belt before
Old 06-04-2009, 06:46 AM
the shroud is made to be cut and bolted back together once finished...iss that how you took it off?
I imagine i'll take it off in pieces with a sawsall and trash it. It really don't need to be on there.
Old 06-04-2009, 07:04 AM
Takes about 5 minutes to change a belt on a 6.0.
Stand on the pasenger side pull the belt with all your might, reach down below the tentioner pully and flip the little metal clip. The tentioner will release remove the belt, snake the new one on pull the belt again, reset the metal clip and your done.
I will add that this is much easier with to people one to pull the belt and one to move the clip.
I will also add that I couldnt figure this out a couple months back and called Scuffy on the phone and he told me how to remove the belt.
