BATTERY? - Ford Powerstroke Diesel Forum
Old 06-02-2009, 02:54 PM
BATTERY?
TIME TO CHANGE THE BATTERY,SHOULD I GET THE STOCK MOTORCRAFT,OR ARE THOSE NEWER RED GEL TOP BATTERIES A BETTER CHOICE,THANX FELLAS.
Old 06-02-2009, 03:11 PM
Send a message via Yahoo to Lubbockguy1979
I haven't had good luck with the optima type gel batteries... I got autozone 1000cca duralast gold with a 3yr warranty. I was told when buyong both at the same time if one failed they would replace both. Remember to get both to avoid having more battery issue
Old 06-02-2009, 03:14 PM
BUY BOTH,OUCH,HOW MUCH IS THAT GONNA RUN ME BUD.
Old 06-02-2009, 03:28 PM
When you buy one battery the old weak battery starts to pull on the new battery. This will cause the new battery to work harder to maintain a charge also make the altenator work to charge them both. When you replace the batteries at different times you will be killing a lot more batteries and having charging issues more often. . One battery was bad but in the process of trying to get by and use a used battery I ended up killing the altenator. So I decided to follow the recomendations of others and get them both and I think I spent $120 on them and $150 on the altenator. That was in febuary haven't had a issue since
Old 06-02-2009, 03:30 PM
285,261,190
yep I agree replace them both so you don't have any issues. I replaced mine with the stock motorcraft. I feel its a good battery. I have had 0 issues starting and using my 12k winch
Old 06-02-2009, 03:40 PM
THANX ALOT FOR THE RESPONSES,I WILL BE GETTING 2 NEW BATTERIES TOMMOROW.
Old 06-02-2009, 03:56 PM
Powered by Deez Nuts
get the gold top duralast batts from autozone.
