Interested in racing, But don't want to look like a tool!! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-31-2009, 07:55 AM Thread Starter
So Truck is listed below, 4x4 with manual hubs... So explain what I need to do... Whats a boosted launch? Do I launch in 4wd? I am new to this so any help is appreciated...
2006 F250 XLT CCSB 6 Speed Manual
8" Lift
PRO COMP TYPE 8089 18" WHEELS
37" INTERCO VORTRAC AT's
4" Turbo back to stacks
Tunes by Eric
traumajunkie21 is offline
post #2 of 13 Old 05-31-2009, 08:08 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
boosted launch means hold brakes and hit throttle to build boost. I build to about 15psi. Be carefull though depending on tire pressures it can lead to wheel hop.
Also with your manual doing that can be very difficult
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 13 Old 05-31-2009, 12:01 PM
mdub707's Avatar
Yes in 4x4! I boost to about 17psi in mine. Its really going to depend on your setup though. I'm running no lift and smaller tires (33x12.5x17's). Mine bites real good with this setup.
DamnKids Motorsports
2006 F-250 6.0 4x4
Innovative Diesel Tuning 466/772 7/19/08
VEGISTROKED
mdub707 is offline
post #4 of 13 Old 05-31-2009, 12:08 PM
dzchey21's Avatar
boosted launchin with a manwel is going to be hard, you have to get all three peddles going at once, and assuming your on a stock clutch, its really not meant for that. if you can load the engine down a little before you launch that would be good, a line lock would be perfect for you ....
single turbo'd 6.4
dzchey21 is offline
post #5 of 13 Old 05-31-2009, 12:15 PM
kylev90's Avatar
Quoted: 4 Post(s)
has anybody tried using the E-brake to build boost in a manual? I just cant get all 3 pedals right and usually just end up lookin like an ***........
1997 CC SB. Stage 1s, 17*hpop, S&B CAI. 4" straight pipe, TW tunes, zf5 swap
kylev90 is offline
post #6 of 13 Old 05-31-2009, 12:24 PM
dzchey21's Avatar
on an obs truck it might work, but superduty park brakes arent really known for there holding power since they are about 1/3 the size of the old drums on an obs truck, might be something to try... not at the track your first time LOL. THree peddling is super hard but with some practice ive seen dudes do it better than others with an auto.
single turbo'd 6.4
dzchey21 is offline
post #7 of 13 Old 05-31-2009, 05:38 PM
I can launch the crap out of a manual.....but I think he has an auto, he said manual hubs.
2006 F-250 4x4 ecsb, Elite stage 2's, VGT-SSX.
Vizsla is offline
post #8 of 13 Old 05-31-2009, 05:40 PM
dzchey21's Avatar
I think it says 6 speed in his sig bro
single turbo'd 6.4
dzchey21 is offline
post #9 of 13 Old 06-02-2009, 06:32 PM Thread Starter
ok so When i used to burn tires on my ranger i would do the three pedal thing..same general concept? Just more brake?
8" Lift
Tunes by Eric
post #10 of 13 Old 06-02-2009, 06:34 PM
dzchey21's Avatar
Yup if you can do that, without learching forward you should be good, be advised though a stock clutch cant handle a ton of that.
single turbo'd 6.4
dzchey21 is offline
