exhaust help please - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-28-2009, 11:09 AM Thread Starter
exhaust help please
I am in the middle of installing a 4" magnaflow turbo back exhaust on on my 03 f-350, I cut the down pipe just in front of the cross member but am having a hard time geitting it out. I assume that it comes out from the bottom is there anybody could give me tips on how to get that thing out of there. Thanks
kahall75 is offline
post #2 of 5 Old 05-28-2009, 12:14 PM
hazard's Avatar
if you cut it in front of the crossmember, it should just wiggle out of there... ive done 2 trucks now a 05 and my 06 and i cut both of them in front of the tranny crossmember and wiggled them on out. you may have to lift it up a little, there is a small hanger on the top of the flange where it mounts to the turbo but im sure you would have seen it when you took the clamp off, i cant really think of anything else that would help you. youll get it.
Thanks,
Adam
2006 F-250 6.0L CCSB Lariat 4x4, ARP studs, SCT tunes by innovative diesel, Silverline 4" turbo back exhaust no cat no muffler! Upfitter switches w/high idle mod, Edge Insight monitor w/EGT probe, autometer fuel psi gauge, Zoodad mod with billet plate. Ford Updated fuel psi spring and banjos, RCD egr delete, Ford updated oil cooler and stc fitting, dieselsite cac boots and coolant filter.
1984 Mercedes Benz 300D Turbo Diesel, cold air intake.
"Run Hard, Dream Big"
hazard is offline
post #3 of 5 Old 05-28-2009, 12:14 PM
back to business
07OUTLAW's Avatar
It does come out from the bottom.
Is it still attached to the turbo? When I did my exhaust the hardest part was getting the old down pipe off the turbo. The band clamp came off easy enough, but it took lots of banging, wiggling and cursing to get the pipe to break loose.
Good luck
Duane
2007 - F-250 Lariat OUTLAW
1983 - MERCEDES-BENZ 300D
07OUTLAW is offline
post #4 of 5 Old 05-28-2009, 12:22 PM
purplehorn1977's Avatar
bend the little tab that holds the flange to the turbo and it will fall off of there
2004 F250 6.0 CC 4x4 SCT with custom tunes
zoodad mod, head studs, Home Brew EGR delete, 5" MBRP striaght exhaust, 05 headlight Conversion
HID Head and fogs.
Real courage is found, not in the willingness to risk death, but in the willingness to stand, alone if necessary, against the ignorant and disapproving herd. Jon Roland, 1976
purplehorn1977 is offline
post #5 of 5 Old 05-28-2009, 12:52 PM
orng1's Avatar
Quoted: 3 Post(s)
Yeah have to get in there with a screw driver and bend those back, a little penetrating oil helps too.
Bob
2001 F250 SRW Reg cab, long bed, 80k miles.
Now with DP tuner, Airaid intake and 4" Magnaflow turbo back exhaust.
orng1 is offline
