EGR delete ?
ok so i am about to take on the task on deleting my EGR. i will be doing it all homemade not buying any of the kits i am broke. but i think my cooler is starting to leak i have been getting a little white smoke at start up in the mornings. my ? is what all parts will i need as far as gaskets and what not to complete this?
I can't help you answer your question but I'm willing to come help! I'd like to get a look at what all is involved as well.
Mine is at Bowditch getting a new cooler installed now (2nd time under warranty) After my warranty runs out I want to get rid of mine also. |
get a gates 1806 hose and take your old egr cooler out cut all the flanges off and weld them closed cut the pipe off as close to the cooler body as you can and then cut the oring flange off the cooler as close as you can also. weld the pipe to the oring flange and then take the intake ans install the oring flange with the pipe welded on it into the hole in the bottom of the intake. after that bolt the flange that held the egr cooler to the intake in place and weld a support bracket to the oring flanged pipe to hold it in place. just make sure that its straight back. install intake with the old intake gaskets install the blockoff flange in the exhaust and install the hose to the oil cooler and the pipe that you welded up put clamps on the ends filler her up and drive the snot out of it.
ok kinda lost me. alot of info really quick. you wouldn't happend to know of a good right up with pics do you. what about the parts that are involved like gaskets that will need to be replaced when doin this. |
its really easy if you are carefull when you remove everything all you will need is a turbo mounting kit like 8 bucks from ford or ih dealer the gates hose all other gaskets can be reused. i know there is a write up on here somwhere. do a search there is a write up somone did. man if you were closer you could come out and id show you how to do it. it aint hard
ok i found the write up on the delete and it says use freeze plugs to weld in to block on the exhuast flow but what size? and where do i get that hose from?
edit: nevermind I found it Complete EGR removal write up |
good luck this is the same way that i did it only my cooler was the newer square style so i had to change it a little bit but it works great lower egt and no more puking.
but where did you get the hose from and what size freeze plugs did you use
