Max Temps - Ford Powerstroke Diesel Forum
post #1 of 13 Old 05-27-2009, 03:36 PM Thread Starter
Goose350's Avatar
Max Temps
What are the max temps I should be seeing on my truck. I know the transmission and egt but what about the coolant and oil temps?
The Mullet Mod
Stock 2005 F-350 4x4
*Afe Intake
*4" TB Exhaust
*Scangauge
*SCT
oil bypass
water pump
*Tuned FICM
Goose350 is offline
post #2 of 13 Old 05-27-2009, 06:24 PM
smokersteve's Avatar
Quoted: 19 Post(s)
I wouldn't go past 240 for water and 250 for oil. If I get to that point I would turn to just fog lights (night) and turn off all in cab stuff like radio AC laptop. And turn on the heater. If It gets hotter Id pop the hood and spray water on the grill for a long time. Then do something about keeping the heat down better for next time.
13Q Trans Fluid Flush
FICM Testing Videos
smokersteve is offline
post #3 of 13 Old 05-27-2009, 06:32 PM
Huh? WTF?
2005F250 is offline
post #4 of 13 Old 05-27-2009, 06:33 PM
Cruising I see anywere from 180-211. Towing I see 190-227. Oil should be whithin 5-10 degrees of that.
2005F250 is offline
post #5 of 13 Old 05-27-2009, 07:39 PM
Quoted: 19 Post(s)
Originally Posted by 2005F250 View Post
Huh? WTF?
they take more engery!!!
if It gets way too hot I will cool it down. Turning on the heater will take heat from the eng. And switching the lights is only for night if it gets hot then.
I will change things on the truck to run cooler.
FICM Testing Videos
post #6 of 13 Old 05-27-2009, 07:43 PM
Quoted: 19 Post(s)
Thats also what I see normaly
FICM Testing Videos
post #7 of 13 Old 05-27-2009, 07:53 PM
According to the Ford PC-ED manual, the computer starts to defuel at 221 *F coolant temp and at 254*F oil temp. Aftermarket gauges, depending on where the probe is installed, can read slightly different temps than what the truck computer sees.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #8 of 13 Old 05-27-2009, 07:56 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 9 Post(s)
I have never seen over 207 as far as coolant temp on mine.Even towing so far
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #9 of 13 Old 05-27-2009, 08:13 PM
I can see A/C being the only thing that will make the engine work harder. Turning off the headlights to lighten the engine load doesn't make sense plus it's dangerous and stupid to drive at night with just fog lights. As for spraying the radiator with the garden hose that radiator is gonna be hot and your gonna shock cool it with cold water? Doing that runs the risk of warping and cracking the radiator. If the engine gets hot pull over and let it idle untill temps go down. If it's not cooling down because all the coolant is gone then shut it off.
2005F250 is offline
post #10 of 13 Old 05-27-2009, 08:19 PM
Quoted: 19 Post(s)
I can see A/C being the only thing that will make the engine work harder. Turning off the headlights to lighten the engine load doesn't make sense plus it's dangerous and stupid to drive at night with just fog lights. As for spraying the radiator with the garden hose that radiator is gonna be hot and your gonna shock cool it with cold water? Doing that runs the risk of warping and cracking the radiator. If the engine gets hot pull over and let it idle untill temps go down. If it's not cooling down because all the coolant is gone then shut it off.My perspective is from a normal operating eng
Ya im not sure what I was thinking with the lights...................
I understand warping could be a problem.
I for got to also point out it also depends where the temp sensors are placed.
FICM Testing Videos
