High Idle Mod? - Ford Powerstroke Diesel Forum
Old 05-27-2009, 05:46 AM
High Idle Mod?
Hey guys I am a not new to diesels but this is my first PSD and I am seeing "High Idle Mod" in a lot of sig's. Could somebody fill me in on what that is and the benefits to it and ant othe little trick I can do? Thanks in advance.
Old 05-27-2009, 05:52 AM
Pointless Poster
it helps for warmups on colder mornings . i need to do it soon myself.
Old 05-27-2009, 10:30 AM
What is required to do it?
Old 05-27-2009, 10:33 AM
one way would be to buy a chip for your truck with the high idle setting on it
Old 05-27-2009, 05:03 PM
Ask and ye shall receive...
Engine Idle Control Mod
Old 05-28-2009, 10:59 PM
I did this mod this past winter and did it ever make a difference in warming the truck up. I didn't have the upfitter switches so I bought a set off E-bay for about $160. Install took about 30 mins. I used switch #4 for the high idle, leaving 1-3 for aux lights etc.
I used this link for my install:
TikiWiki : Upfitter Switch Kit
Hope this helps.
Old 05-29-2009, 01:38 AM
say no to rolling coal
It's a 6.0L. No "chips" for a six oh.
Hope this helps.
Mine cost me about $6. A toggle switch and a couple feet of 16ga. wire with an inline fuse from the local hardware store. One end goes to the hot wire by the OBDII port, the other to the PTO wire in the bundle under the fuse panel. I mounted the switch on the side of the black plastic cover under the center of the dash directly over the tunnel on the floor.
Old 05-29-2009, 06:30 PM
Thanks, It will be done this weekend, any idea what color wires I look for on an 04?
Old 05-29-2009, 06:37 PM
High Idle Mod
