Defuel question????
This is kind of a broad question but I would like to know what sensors would cause my truck to defuel?
that would be your map sensor. it monitors your boost levels and when it gets to 22 or 26ish. somewhere around there it tells the computer hey i dont think this is safe easy on the fuel.
is there a way to test it?
You begin to defuel on coolant temperature at 221 degrees F according to the PC-ED manual; on oil temperature at 253 degrees F; at 4000 rpm's; and at 95 mph.
cliford - I was not aware of the MAP sensor being part of the defuel strategy. Do you have a reference for that? |
yea just use the search function at search boost fooler. what do you mean test it? |
Does this apply to a 6.0L also? or just 7.3L
man im horrible at looking at what section things are posted
Do I need a boost fooler for a 6.0l? |
Acceptable spec is within 20 degrees of each other |
