Transmission Upgrade ?
I am getting ready to have my trans. built and wanted your guys opinions on these parts:
1) Billet input shaft
2) Alto Red Eagle Clutches and steel's
3) Transgo Shift kit
4) 1600 RPM stall Stallion Torque Converter
The Clutches, steel's, and shift kit all come in a package. Below is the description:
Clutch pack upgrade, overdrive 5 alto red eagle clutch plates & kolene steel's - scd pressure plate - scd overdrive piston, intermediate 5 clutch plate's & 5 kolene steel plate's - scd pressure plate, forward 5 alto red eagle clutch plate's & 5 steel plate's, direct 6 clutch plate's & 6 steel plate's - scd pressure plate - scd apply piston, low & reverse 6 alto red eagle clutch plate's & 6 kolene steel plate's, and 1 shift kit.
Any advice is appreciated. The above parts add up to a little more than $2,000, so I want some advice before I have any parts ordered.
Thanks again,
French
