relocate icp sensor - Ford Powerstroke Diesel Forum
Old 05-19-2009, 06:34 PM
relocate icp sensor
Is there a way to relocate the icp sensor on an 03-04 6.0L. I have not changed mine yet, but i did locate it and boy o boy will this be fun! Is the icp sensor NPT threads? I was jsut wondering if anyone had done this? I am going to have this truck for awhile and i know it will only go out again. Thanks for any information you can give.
Old 05-19-2009, 07:43 PM
I am not aware of any relocation kit. but that's a really good idea if it will work. Personally I can have one off and back on in about 10 minutes at a reasonable pace. But the first time was a real pain. Ive just learned to go at it
over the bell housing.
Old 05-20-2009, 03:52 AM
I guess i could get a SS braided hose rated for the psi and make like an extention for the ICP. Make a clean looking bracket for it and be done with it. If the ICP reads only pressure then this would work correct?
Old 05-20-2009, 04:10 AM
You are also going to want a way to get all the air out (I would think).
Old 05-20-2009, 04:58 AM
Good point idk if the air would works its way out or not? I wonder if i could mount it lower than where it ties into the HPOP cover and let the air work its way out naturally? Oh does anyone know what size socket the ICP is and if it 12pt or 6pt? And also the cheapest place to get one? Thanks foe the help yall.
Old 06-03-2013, 08:09 AM
Were you able to do this mod? I would be interested in doing the same if you could share some info.
