Turbo Q? - Ford Powerstroke Diesel Forum
Old 01-28-2007, 07:59 AM
Turbo Q?
I'm starting to get a strange hollow howling noise from my turbo while passing cars at highway speed. first the turbo whistle starts then it goes to a howl. What does this mean? Am I going to have issues with my turbo soon?
Old 01-29-2007, 03:41 AM
Turbo?
Anyone????
Old 01-29-2007, 04:31 AM
ADMIN AND TECH
you might have two things happening ,either the turbo is stuck open and it will cause ,a bad howling at higher boost or you have a split in the intercooler boot which wil also cause a abnormal noise only under heavier accell, need to get it looked at , have codes pulled ,if turbo is stuck ,it wil probaby ie code p0299, needs to be cleaned or replaced , have them look at the intercoler boots
Old 01-29-2007, 12:21 PM
Scott W
Thanks for the info. I checked for any codes and there are none, also checked the inter cooler boot and it looks fine. I suppose I should bring her in anyway.
Thanks again
Scott Pavao
