6.0 wont crank - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-14-2009, 11:30 AM Thread Starter
6.0 wont crank
hi yall i have an 03 6.0 that wont crank replaced both batteries and the altenator thaey were bad not getting power to the starter i checked it and it cranks when i bypassed it with a acrewdriver any ideas would be great the parts house thinks it either the little wire that goes to the starter or igniten switch thaks in advance.
Troy is offline
post #2 of 5 Old 05-14-2009, 11:59 AM
Justinlw's Avatar
Quoted: 28 Post(s)
Send a message via MSN to Justinlw
Check your fuses. You may have a solenoid that's going bad. This could cause a load spike and blow the crank fuse.
2010 F250 Lariat FX4 6.4l
Carli Backcountry 2.5", 11+ Leaf Springs, SCT 3015R/Tyrant Tuned, Edge Insight CTS,
FloPro DPF Pipe, RCD EGR Delete/Elbow, Sinister Coolant Filter, 11+ Console
Justinlw is offline
post #3 of 5 Old 05-14-2009, 12:54 PM Thread Starter
thank you will look at that
Troy is offline
post #4 of 5 Old 05-14-2009, 01:01 PM
ADMIN AND TECH
SCUFFY828's Avatar
blown fuse i agree
ITS STOCK
SCUFFY828 is offline
post #5 of 5 Old 05-14-2009, 02:39 PM Thread Starter
one bad fuse replaced it and still nothing
Troy is offline
