Data logging on X-ca2????? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-13-2009, 12:59 PM Thread Starter
So I loaded Livelink IV installed all the drivers and when I hook the x-cal up to the computer it does not connect to the device.
All the other programs find my x-cal its only livelink that is not working.
I made a DLF fie with live link do I need to load this onto the tuner to be able to data log?
__________________
06 F350 Traded
alwil is offline
post #2 of 10 Old 05-13-2009, 03:48 PM
It is complicated, that's for sure, but is worth getting operable. You have to create a file with the pids you want to watch, load it on the device, then select the pids on the handheld that you want to watch. Some of the values will not make sense, but once you take your info you datalogged from the handheld and load it back to livelink, it translates it into a graph that is easy to read. You can also pass it through the device directly to a laptop in the vehicle if you wanted, the hanhelds only record for a little bit-90sec. on my X-Cal 2.
2006 F-250 4x4 ecsb, Elite stage 2's, VGT-SSX.
Vizsla is offline
post #3 of 10 Old 05-13-2009, 04:24 PM
CCSBD's Avatar
If you data log will it help someone the innovative to write you a better tune? What is the benefit of data logging
***SOLD***
'04 CrewCab ShortBed 6.0 4x4
Black FX4 Sport
6K HID's
CCV Mod
03 Turbo
6.4 Banjo's
Zoodad Mod
4.5" Icon Lift
High Idle Mod
ARP Headstuds
RCD EGR Delete
Updated FPR Spring
Sinister Coolant Filter
Recon Smoked Cab Lights
SCT X3 Tuned by Innovative
4" MBRP SS Turbo Back Exhaust
ISSPRO EV pyro, trans, boost guages
CCSBD is offline
post #4 of 10 Old 05-13-2009, 04:47 PM Thread Starter
I think it helps trouble shoot sensors and stuff.....
06 F350 Traded
alwil is offline
post #5 of 10 Old 05-13-2009, 04:48 PM Thread Starter
thanks for the reply....thats what I was wondering.
06 F350 Traded
alwil is offline
post #6 of 10 Old 05-13-2009, 07:12 PM
Don't think it will help with a tune unless you end up with a wierd problem. I use it to check HPOP and eot vs. ect. Glad I could help.
Vizsla is offline
post #7 of 10 Old 11-22-2009, 07:32 AM
elm302's Avatar
Feedback Score: 3 reviews
so im doumb when it comes to computers but how do i set all the data capture stuff up i have a xcal 2
2003 F350 Lariet Leveling kit eagle 197s MBRP stainless tb to 6" stack Sinister coolant kit Sct with Looney and Innovative High Idle fog light and bright box mod soon to come Edge CTS PHP ficm tuning and Cab lights
elm302 is offline
post #8 of 10 Old 11-22-2009, 12:59 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 141 Post(s)
Took me a few tries to figure out the PID file. Then once it's all together you can run the truck while the graph is displaying on the computer.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #9 of 10 Old 11-22-2009, 01:29 PM
elm302's Avatar
how do i get started tho when i go to data capture all it says is no capture files loaded
elm302 is offline
post #10 of 10 Old 11-22-2009, 01:32 PM
N.S.D.Q.
Quoted: 141 Post(s)
You got to select the PIDs to monitor first. It's been a long time for me and I can't recall exactly.
