Maybe an SCT problem? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-26-2007, 07:52 AM Thread Starter
trackmagic's Avatar
So i have been driving my truck for awhile on my street setting, and on the race setting. The truck doesnt run that well. It never feels like I have any power on tap, and only under full throttle does it seem to run well. Also, while cruising at a certain speed, the truck will sometimes start to buck even though I am holding a constant throttle pressure. I assumed the problem was because I had a bad Injector sensor, but I got that replaced at ford yesterday, and it didnt change anything.
Any ideas on what it might be, or do you think I need to get new tunes?
1997 F350 CrewCab 7.3
Toyo M/T 35's (Stock height)
Superwinch Manual Hubs
Farmboy Diesel Straight Pipe
Tony Wildman 4pos Chip
A-Pillar Gauges
trackmagic is offline
post #2 of 5 Old 01-26-2007, 08:33 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 29 Post(s)
Feedback Score: 4 reviews
Call the dealer that you got your SCT from and ask them. They may have seen this problem before. My thoughts are that its probably something wrong with your truck, not the SCT because it doesn't sound like it has always been a problem, but I'm not a SCT guy so it could be. I think that there were some issues with bad turbos in the year of your truck.
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #3 of 5 Old 01-26-2007, 08:45 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
Take the tune out and put the factory tune back in and see what happnes, that will tell you if its the tune or not.
Bucking can be cause from other things - injector related. Hope its the tune and not failing injectors!
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #4 of 5 Old 01-26-2007, 08:47 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 30 Post(s)
I might add, i have the same exact engine you do and when my injectors failed, it bucked like your saying. Check your oil level! If its overfull and smells like diesel fuel, DONT drive it.
post #5 of 5 Old 01-26-2007, 11:57 AM
Send a message via AIM to CBSuperDuty Send a message via Yahoo to CBSuperDuty
True but sometimes because everything is amplified with a tuner, the problem may not be as noticable.
CBSuperDuty is offline
