Crazy! ABS Light - Ford Powerstroke Diesel Forum
Old 05-11-2009, 12:20 PM
Crazy! ABS Light
Does anybody elses truck while cruise down the highway on a long trip the abs light will just suddenly pop on? My 2 06's both do this but sometimes it kills the truck for about 5sec. and then refires runs fine but have an abs light any ideas?
Old 05-11-2009, 12:55 PM
Mine also
Old 05-11-2009, 01:12 PM
My 06 has also done this for no apparent reason. I was driving for about four hours towing some quads and it just popped up and then went away later on. It is weird that your truck died, that's weird.
Old 05-11-2009, 01:53 PM
Mine did too. I found moisture in the rear speed sensor connector.
Old 05-11-2009, 05:22 PM
16hr trip in my truck towing a 30ft enclosed and i didnt have one problem with anything
Old 05-12-2009, 03:54 AM
Since this has done this with both my 06's and you other guys have 06's I guess its only an 06 problem? I was guessing a bad drivline speed sensors has anybody replaced this and remedied the problem? My couisin has a lifted 05 and his rear driveline speed sensor in the rear diff is not even hooked up and he has an abs light all the time so I know a problem with it will cause an abs light.
Old 05-12-2009, 03:56 AM
We also have an 04 with problems like this.
Old 05-12-2009, 10:39 AM
Any techs have an idea?
Old 05-15-2009, 05:28 PM
Light came on again tonight got the SCT out to try and read a code but there isnt one even with the ABS light still on I went to read DTC and says there no code anbody fixed this problem thats had it?
Old 05-16-2009, 06:59 PM
I went to autozone to have the codes checked tonight and nothing. I also pulled the driveline speed sensor and it looked fine anybody have a part number for the driveline speed sensor for an 06 f350 4x4?
