Zoodad on '03 6.0 - Ford Powerstroke Diesel Forum
Old 05-06-2009, 07:21 PM
Question Zoodad on '03 6.0
Just wondering opinions on doing the zoodad on a stock '03 6.0? Thanks in advance
Old 05-06-2009, 07:24 PM
you tear a hole as wide open as you can for that poor smothered dieselwagon
Old 05-06-2009, 07:27 PM
The previous owner of my truck performed this mod. I'll get pics up tomorrow of what he did. He used screws to cover the holes with regular screen to keep the bugs and junk out. I can really hear it sucking air when I shut the truck off. Maybe the AFE helps with that though. I'd recommend it.
Old 05-06-2009, 07:29 PM
Tennessee Powerstrokes
All it is is a hole cut out in front of the air filter so it can draw more air in. When you remove the grille you will be amazed that you motor was even able to run. Cut out about a 4' X 6" hole and cover with some fine mesh screen replace the grill and have fun!
Old 05-06-2009, 07:32 PM
Sounds like some good, Cheapstuff...I guess I'll have my project for mothers day afternoon
Old 05-07-2009, 09:13 AM
Here's my zoodad. Easy cheap mod. At cruising speed My IAT1=IAT2 or the air temp in the intake manifold is the same as the ambient temperature. Well worth the few minutes it takes.
Old 05-28-2009, 08:12 PM
dieselwagons running hot all day ....ZOODAD < ZOODAD
dieselwagons running cool all day , all the ZOODAD DAY
