Bilstein 5100 help ASAP - Ford Powerstroke Diesel Forum
Old 05-06-2009, 01:23 PM
Send a message via AIM to Gear Jammer
I havge a 2004 f-350 SRW do these mounbt with the shock boot at the bottom??? I Am putting them on now and they will not mount with the shock boot at the top.
Old 05-06-2009, 01:26 PM
Mine did on my 2000.
You have to turn the lower portion, so it will bolt up
Old 05-06-2009, 01:29 PM
WTF i think the shock boot on the botton look retarded. O well i guess i will have to live with it. Im not going to send them back and all that BS. I hope the ride is worth it.
Do the fronts mount the same way?
Old 05-06-2009, 01:34 PM
I got it... The bilstin logo is right when the shock boot is at the bottom. If the shock boot is ta the top it is upside down.
WTF im kinda pissed about this. O well next go around i stick with rancho.
Old 05-06-2009, 01:35 PM
I thought you were referring to the front. That's what i was talking about.
I assume the rear is the same as the front?
I only have bilstein's on the front at the moment. need to order rears.
My pro comp's that are on the rear now have the boots on the bottom as well tho
Old 05-06-2009, 01:39 PM
Boots on the bottom in the rear and at the top in the front
Old 05-06-2009, 01:41 PM
I installed my 5100's on front with the boots at the bottom. The bilstein logo would be upside down if i hadn't.
I thought that's the way they were suppose to go
It isn't hurting anything is it?
I don't use the boots nor do a lot of other people because they are just a trap for dirt
Old 05-06-2009, 03:49 PM
I just checked mine and my boots are on the top in the front and back. I don't know if the diagram showed them that way, but I did it that way to ensure that dirt didn't gather in there (at least gravity would be working against it).
Let us know what you think about the 5100's....as far as the ride is concerned.
Old 05-06-2009, 03:58 PM
The ride is nice Alot better then the 5 year old stock ones.
Well i put all 4 on with the shock boot at the bottom. As far as the rear shocks go that was the only way. If you try to mount them with the boot up the hole was to small on the shock to put in the truck shock mount bolt thingy.
I think the boot goes to the bottom on the front too. Cuz the logos are right that way. I dunno they came with no directions what so ever.
