Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 01-24-2007, 01:49 PM
CheM CheM is offline
Help me decode this OASIS report..
11.6 hours of labor 4-13-04
Cust Comments: CUST REQ PERFORM FSA 04B24 REV PLANETARY REPLACEMENT
Tech Comments: RECALL O4B24 INSTALL PARTS PER RECALL
4.3 hours 5-5-05
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT INTERMITANTLY IS COMING ON AND OFF....CHECK & ADVISE
Tech Comments: EGR VALVE FAILED EBP HIGH PERF TESTS P0401 KOEO KOER BUZZ PASS ICP TESTS PASS BOOST 25PSI PINPOINT TEST REPL EGR VALVE AND EBP REPROGRAM MODULES
11-5-05
3.8 hours labor
Cust Comments: CHECK ENGINE LIGHT INTERMITTENTLY ON
Tech Comments: EGR VALVE STICKING EXCESSIVE CARBON BUILD UP AFTER RECALLS ROAD TEST P0404 PID MONITOR ROAD TEST KOEO KOER BUZZ PASS ICP TESTS PASS EGR TEST POSITION PINPOINT TEST REPL EGR BOOST TEST 24PSI SR TO RO 74071 052805 22857 MILES
BUILD DATE
03/16/2004 should i be afraid before i buy this truck?
are these bad signs?
Old 01-25-2007, 01:53 AM
lilredpowerstroke lilredpowerstroke is offline
Powerstroke Pimpin'!!!!!!
The guy who owned it before probably babied it thats why it kept making the EGR fail. 6.0's dont like to be babied. They need to be driven hard to keep the carbon from building up. If it was me and the price was right (read very cheap) I would probably buy it if I needed a new truck.
