ICP sensor bad in 6.0 L what and where is it???/ - Ford Powerstroke Diesel Forum
Old 05-03-2009, 03:55 PM
Have 03 6.0L has hard start but runs great when warm. diagnostics show ICP sensor bad. why can't I find any info on it??? Where is it?// can i change it myself. Mechanic also says ICP pigtail must be replaced, oil leaking on it . This just started why is the pigtail so bad? We have Chilton manual and other info but no mention Of ICP. Advice badly needed.
Old 05-03-2009, 05:41 PM
I "think" on the early models its in the back of the engine, the newer ones are up front on the passenger side valve cover.... email powerstrokehelp.com
Old 05-03-2009, 05:46 PM
03 engines it is on the rear of the motor up underneath the turbo. you gotta take the little heat shield off, i think it is 3 10mm bolts and then u need a 1 1/16 sensor socket to fit the icp and take it out. did one on my 03, wasnt too bad once u find it. i got to mine from underneath with it on a lift. kinda need skinny arms or u will scrape yourself up. hope this helps.
Old 05-04-2009, 06:40 AM
I replaced mine without replacing the wiring and it is just fine. As mentioned, it is behind that heat shield, once you get that off it's an easy job.
