Boost Line Placement - Ford Powerstroke Diesel Forum
Old 01-23-2007, 05:25 PM
I have heard that i can tie in to the map line or in the intake port. My ? is were is the map line on my truck ?
Old 01-23-2007, 06:42 PM
im fat and ugly
on the passanger side behind the hot side of the intercooler tube there is a black plate, under there is a plug which is the map sensor, and connected to that is the pressure line you speak of
Old 01-24-2007, 03:22 AM
Send a message via AIM to CBSuperDuty Send a message via Yahoo to CBSuperDuty
I would tap the intake though as many have experianced a tapping sound out of the boost gauge when tied into the MAP line. I hope to change this on my truck soon.
Chris
Old 01-24-2007, 05:09 PM
Hey thanks guys hey stump were does that line go and do i just tap into it anywere?
Old 01-24-2007, 05:23 PM
im fat and ugly
its only about 10-12" long and it goes into the intake manifold behind the hot side of the intercooler tube
im not sure about tapping that line, my boost guage tapped into the map sensor wires
Old 01-24-2007, 07:43 PM
Thank you Sir
Old 01-28-2007, 05:03 PM
Well tapping that line did not work so into the intake i will go.
Old 02-04-2007, 11:36 AM
My Boost Guage Hooked Into The Hose Of The Map Sensor With A Barbed Tee Fitting. The Boost Guage Hose [1/8th Inch] Tied Into The Top.works Great Hope This Helps.
Old 02-04-2007, 01:36 PM
I tapped in to the intake i think it was easier than the map line it works great.
Old 02-05-2007, 11:35 AM
Chris
Hey Chris, could this be what is causing that noise?
3-Gauge Install Pictures
