Straight water ? - Ford Powerstroke Diesel Forum
Old 05-03-2009, 12:25 PM
Question Straight water ?
Has anyone ever ran straight water in the summer ?
The reason i ask is i hear of people running coolant filters because the coolant gets yuckie (i guess).
I know antifreeze must be used in winter & summe it has a higher boiling point
but running straight water in the summer its proven straight water cool`s
faster & longer in the summer then with antifreeze.
i run straight water in my race car & it helps
So has anyone ran straight water in summer, i think it would also be cleaner
just wanted your 2 cents, thanks, Dave
2005 f-350
crew cab, long bed,
AFE,
side exit, 4 inch with 5 inch tip, straight pipe,
2 inch levelling kit
Old 05-03-2009, 01:20 PM
Well there is no lubricating properties in straight water so unless you run water wetter or something its really not a good thing for the water pump
Old 05-03-2009, 01:22 PM
if you were in a pinch you could use straight water because the boiling point of water is 212 degrees, water actually transfers heat better than antifreeze. and adding antifreeze raises the boiling point a certain amount and lowers the freezing point at the same time but it is also providing a small amount of corrosion resistance. all in all i would rather run straight antifreeze or a mix because it will last longer and you wont deal with rust or corrosion
Old 05-03-2009, 01:48 PM
i would run distilled water and diesel water wetter and it should be fine. i just dont like throwing away/ flushing that huge system
Old 05-03-2009, 02:01 PM
thanks guys u made up my mind !
Old 05-03-2009, 05:07 PM
Ford states to never run below 40% and never run over 60%. The reasons are several fold:
1. Corrosion protection (and not just a little, but a lot - especially aluminum).
2. Pump cavitation protection
3. Pump lubrication
4. Deposit (percipitation) control
5. Proper heat transfer
6. Proper boiling point elevation and freezing point suppression
Keep in mind that higher heat transfer may not be the best thing. Skin temperatures of metal cause the coolant temperatures to experience localized areas of higher than average temperatures. This can cause boiling at the metal surfaces and this increases corrosion and solids deposition.
Old 05-03-2009, 05:14 PM
electrolysis???????????????????
Old 05-03-2009, 06:25 PM
i have never ran anything but motorcraft gold in my truck
Old 05-03-2009, 06:35 PM
Rice Hunter
Motorcraft Gold and Distilled here!!
