F250 vs F350 Ride Quality - Ford Powerstroke Diesel Forum
post #1 of 18 Old 05-03-2009, 07:46 AM Thread Starter
I've seen a bunch of threads about F250 vs F350 "specs", what what if your only concern is ride quality. For some reason (still have to research) F350's seem quite a bit cheaper than F250s around here.
I found a 2005 F350 with low miles for cheap. It has a lift and it's a FX4 so I could imagine the ride is horrible. I'm thinking bring it back to stock height and replace the rancho shocks. Was else can you do to soften the ride?
THanks
Ride Everything is offline
post #2 of 18 Old 05-03-2009, 08:07 AM
Rice Hunter
Diesel Freak's Avatar
I have a F350 and love the ride quality. What type of lift and shocks certainly made the ride what it is. Nothing compares to a 4-Link with upgraded shocks IMO.
Lloyd Vice Director of Virginia Strokers
2006 F350 6.0L SuperDuty Lariat 4x4
Magnaflow 4" S.S. Turbo Back, Lost Cat, 5" S.S. Tip
Custom Tuned SCT
6" Fabtech 4-Link Suspension- Dirt Logic Shocks-Dual steering Stabilizers
S.S. Brake Lines
Fumoto oil Drain Valve
Accufab Polished Elbow
BFG 37"x12.5"x18" Load "D" All Terrains
ARP Head Studs
EGR Delete
'03 Turbo Swap
Diesel Freak is offline
post #3 of 18 Old 05-03-2009, 09:19 AM
magnumpeei's Avatar
go and test drive a 250 then a 350. you'll see that the stock ride really isn't much different between the two. The 350 has a bit of a bumpier ride when empty because of the overload springs, but it's not a big difference, you get used to it quickly.
if you're stepping up to this from a half-ton, it'll be a stiffer ride no matter what!
chris
2003 F-350 4x4 6.0L
2" Pro Comp Leveling Kit
305/65R17 Pro Comp Xtreme MT
17x9 Pro Comp Forged US Sabre wheels
295/75R16 BFG AT's (for winter)
Stull Billet Grille
ARP Headstuds
No More Puking!
magnumpeei is offline
post #4 of 18 Old 05-03-2009, 09:32 AM
Powerstroke Techie
Clay Henry's Avatar
Quoted: 31 Post(s)
My 350 is an 03 with front leaf springs...the newer ones have front coils and the ride in night and day better.
2003 6.0 F350 dually on high cholesterol fuel (WVO)
2000 7.3 Excursion also on a high cholesterol fuel
Clay Henry is offline
post #5 of 18 Old 05-03-2009, 09:56 AM
I've got a 2005 F350 and I just recently installed Skyjacker Softride leveling springs. My step-dad has a 2002 F-250 (front leafs) and mine rides much much better. The front rides just a little rougher than the 2007 Chevy 1/2 ton I had. The rear unloaded is a little rougher, but still not bad. I drive around 2000+ miles a month and hate to drive anything other than my truck - the ride is that good!
2005 F-350 6.0 Lariat FX4, Crew-Cab, Long-Box, SRW, Auto
Full EGR Delete
ARP Studs
Coolant Filtration System
X3 with Innovative Tunes
Edge Insight Gauge with EGT
4" MBRP Turbo Back exhaust w/ Cat Delete
Line-X Bed, 6000k HIDs
B&W Gooseneck Hitch
Skyjacker Leveling Springs
2008 Style Rear Diff Cover with Royal Purple fluid
anaconda33 is offline
post #6 of 18 Old 05-03-2009, 10:13 AM
SRW F250's and SRW F350's have the same suspension. Overloads are standard on the F350 starting in 02 and overloads are an option on the F250's under the camper package. When it comes down to it the biggest thing that is going to change ride quality is the wheel base or at least thats how I see it.
2005F250 is offline
post #7 of 18 Old 05-03-2009, 10:15 AM
kdskidoo's Avatar
I have a '97 350 and an '07 250 with a lift. the 250 rode like a cadillac compared to the 350 before I put the lift on it. I still think its better even with the lift but not like it was. the coil over in the front helps but those huge 10" springs under the rear are the killer for me. i'd go with whichever one is the cheapest, but most anything with a lift on will ride rougher than stock.
2007 F 250 superduty Highline Pkg.
10" lift-Rock Krawler coil over 4 link pre-runner system w/ Fox res. shocks all around
dual BDS steering stabs
custom trac bars w/polished stainless inlay w/"FORD" lazer cut in center and flames on ends
Raptor coating on frame axles, etc.
bushwacker pocket style fender flares
Jesse James Lawless 18 X 10 chrome wheels
38.5 X 14.5 Pro Comp Xtreme mud tires
AMI Billet door handles and fuel door
4" turbo back stainless exhaust w/ 5" tips
much more to come
kdskidoo is offline
post #8 of 18 Old 05-03-2009, 10:52 AM
Manatee's Avatar
My 350 rides pretty darn good, especially on the highway. Around town is kinda choppy, but not bad.
I think the long wheelbase helps, also.
Like the other guys may have said, loaded ride is a lot smoother than unloaded
The Manatee
15 F350 Long Bed, Crew Cab, Lariat 4x4, 6.7 PSD
Manatee is offline
post #9 of 18 Old 05-03-2009, 11:31 AM
International Threat
Marty's Avatar
At 100mph she rides like a caddy
2001 F250
11.62 @ 115.79
Owner of Marty's Diesel
Elkton, Maryland
Marty is offline
post #10 of 18 Old 05-03-2009, 11:35 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
i like the ride of mine with 8"s more then I did stock.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
