turbo silencer question - Ford Powerstroke Diesel Forum
Old 05-02-2009, 10:14 PM
So my friend wants me to take the silencer out of his turbo on his 05 6.0 diesel, is this hard to do and will it really make it that much louder?
thanks,
trevor
Old 05-03-2009, 12:33 AM
IM PRETTY SURE ONLY DODGES HAVE SILENCER RINGS, BUT YOU MIGHT WANT TO DOUBLE CHCK
Old 05-03-2009, 12:44 AM
OperationSmile.org
If I remember right all Garrett turbos have the silencer built in and it can't just simply be removed. It has to be machined and even then it usually damagers the turbo. On a Holset turbo (dodge) it is pressed in and can be removed easily. But don't quote me on that
Old 05-03-2009, 02:52 AM
The older '03 turbos could be removed, the '04-newer housings need to be machined. If you want your friends money go for it, but you wouldn't be much of a friend at all.
Old 05-03-2009, 02:59 AM
lifetime member
Originally Posted by HeavyAssault View Post
The older '03 turbos could be removed, the newer housing need to be machined. If you want your friends money go for it, but you wouldn't be much of a friend at all.
this is correct.
