just wondering about...... - Ford Powerstroke Diesel Forum
Old 04-29-2009, 03:26 PM
Hey guys just had some questions regarding exhaust.... Mods can move this if its in the wrong section. When doing a straight exhaust, whats the best size to go with when the motor is mostly stock, maybe an air filter and fuel management system. I want to do a straight pipe, just unsure of the size.
Old 04-29-2009, 03:29 PM
Id think 3.5 or 4 inch would be good if your not going to add a lot of power...
Old 04-29-2009, 03:30 PM
generally a 4" straight pipe is the most common, along w/ a 3.5 or a 4"dp to a 4"straight is most suitable to almost everyone, the only reason to go bigger is because of a slight change in sound, and also for the higher hp truck
a good intake is the DIY intake, just search it and there's good steps to follow
Fuel should be fine, unless you have the high hp
Old 04-29-2009, 03:35 PM
Unapologetically American
Feedback Score: 4 reviews
If your running a 6.0, leave the intake alone it flows very well. You don't want to go any bigger than 4" TB unless your running more than 500 hp. A programmer (SCT) is the cheapest 'fuel management' system.
Old 04-29-2009, 08:26 PM
a buddy of mine bought a Dr. Performance Module for an 06... well he has an 04.... so he wanted to know if I wanted it, how are these? Anyone have any experience?
Old 04-29-2009, 08:29 PM
Berm Buster
4" would be good. I know a guy that has a dodge running about 700hp proven on the dyno and still runs the stock exhaust. It is the biggest sleeper in the world. Im sure you will be fine with 4"
Old 04-29-2009, 08:33 PM
sounds good...... so where would the best place to get this done at? And what do you think the cost would be?
Old 04-29-2009, 08:40 PM
4" TB... but most kits for the 6.0L is a 3.5" DP and flares out to 4"
Old 04-30-2009, 04:39 AM
I've never heard of that module your buddy has, but I would recommend using a SCT ONLY. Get with Raul, he'll set you up a great deal on a package (exhaust, SCT, and guages) :burnout
Old 04-30-2009, 04:42 AM
wriott
Guest
Posts: n/a
yup get with Raul and get the SCT
