Injector Replacement on '03 6.0 - Ford Powerstroke Diesel Forum
Old 04-29-2009, 05:35 AM
I am a neewbie to the site and to diesels...I am still thinking of buying the '03 6.0 Dually I have been driving for the past few days. I just wanted to know how hard it is to replace an injector myself if one goes bad. I don't know that much about deisels, but I am learning real fast. The dealer had the egr valve replaced the other day by the ford dealership. BTW I am very mechanically inclined even though I am a schoolteacher and football coach. Also, how much will injectors cost if I have to replace one myself. Any other info you wish to share will be appreciated. Thanks Guys One more thing...I looked at an '02 Duramax and found out it was notorious for injector failure and injector pump failure...Anything like that for the '03 6.0? The truck has 149K on it and has only been brought in for recall work...No major warranty claims in the history...What do ya'll think?
Old 04-29-2009, 05:55 AM
in the early 03 trucks they were using C94 injectors which later faded out and all the 6.0s were using C95s. they said they were better and whatnot. I didnt think so because i had 6 C95 injectors that were put into my truck before me and i had to replace 2 of them.. Injectors if you were buying from the dealer are alot but if you know someone local, junkyard or whatnot then its def way cheaper. I have a buddy who works at a junkyard and i get injectors for 75 dollars a piece.
Changing them out isnt a hard job, take a little time and it could be a dirty job but all in all its pretty easy and you dont need alot of tools.
BTW the 03 trucks IMO are the best year for the 6.0s.
Old 04-29-2009, 06:20 AM
Here is a Pic of the truck...
Old 04-29-2009, 07:25 AM
nice 2wd?..lower that pig
Old 04-29-2009, 08:00 AM
Nah...Trucks arent made to be lowered!
Old 04-30-2009, 11:45 AM
yyyyyaaaa!!!!
Old 04-30-2009, 04:34 PM
they are not that hard to change. if you have any mechanical ablility, you would do just fine. just follow the procedure and your good to go.
clarence
