ummm yea - Ford Powerstroke Diesel Forum
Old 04-28-2009, 05:28 PM
ummm yea
I am confused now
I am coming across all these different part numbers for headgaskets and cant seem to find anything to tell me the difference in them? I am assuming I need the 18mm gaskets but I have came accross these part numbers:
4C3Z-6051-EA
5C3Z-6079-D
4C3Z-6051-EB
Can someone please tell me the difference in these part numbers or which part number I need to use?
Old 04-29-2009, 07:11 AM
Old 04-29-2009, 04:01 PM
anyone?
Old 04-29-2009, 04:31 PM
not sure about the middle one but i will bet that the first and third ones are head gaskets for left and right sides. i know my 5.4 truck had 2 different numbers for the HG respective to each bank
Old 04-29-2009, 04:48 PM
hold on. i'll be right back!!
Old 04-29-2009, 05:07 PM
the numbers on the top and bottom dont come up but i am guessing that they are indeed the actual gaskets. the middle number is a valve grind gasket set. basically all the gaskets neede to take the heads off to do valves. if you are looking for just head gaskets, i suggest phoning the ford dealer with your vin or just order the valve grind set. it comes with everything needed for a 18mm or a 20mm including 2 types of up pipes ( different length )
not to promote ebay but there is one example on there for you to take a look at.
clarence
Old 04-29-2009, 05:09 PM
This is the main reason I am asking cause both of these are on ebay for decent prices and dont know if they will work seeing they are both different part numbers
eBay Motors: 6.0 Powerstroke Head gasket set 03 04 05 06 (item 150341810895 end time May-03-09 20:18:41 PDT)
eBay Motors: 6.0 head gasket set (item 180351281964 end time May-04-09 12:26:22 PDT)
kinda iffy anyways since they have not sold much stuff
Old 04-29-2009, 05:12 PM
the first one you posted is the one you want. that is the one i was referencing to. it is the identical kit i bought when i did mine and i have parts left over cause mine was the 18mm one as well. 05 and up i believe is the 20mm.
good luck!
clarence
p.s. i would go for the top one. feedback is good!
Old 04-29-2009, 05:15 PM
Sweet! He is in Indiana too so about to mapquest to see how close and maybe can skip on shipping
Old 04-29-2009, 05:17 PM
nm shipping is cheaper
