X3 live load download
Anybody have a link to the stuff I need to download so I can put tunes on my SCT X3?
SCTFlash Downloads
Just make sure you load the liveload software before you ever plug the SCT into your computer the first time! FYI as well I was having trouble with the device staying on when I plug it in for a long time. SCT finally admitted there was a problem with a lot of USB ports not supplying enough power to keep the device on. Their suggestion was to plug it into a externally powered USB hub. That works. So if you have that issue, try that. |
I like your avatar Davey
My bad on what it was called Redneck. It's actually X3 Enhanced Updater, not liveload. Select your part number, software and search. It should be the only thing to come up if you have a 3000p/n.
Thanks CC
![]() I found that somewhere years ago and hung on to it. Knew it would come in handy sooner or later! |
So I dont have to download the the firmware? I found some instructtions on the install and I did it to a T and I went to unplug the programmer and the computer screen went blue I dunno but anyways still no worky?
I bought my X3 in mid 2007 is it necasary to update the firmware?
I would if a later version is out
