Tires (Will they fit?) - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-25-2009, 08:14 PM Thread Starter
Switchrider900's Avatar
I have a 05 F-350 Diesel. I'm in need of new tires. I have found a set that are BF Goodrich 31''x10''(P275/65R18) on a Ford 18''rim. They are off a -150.
Will they fit a F-350?
thanks in advance for the help.
Switchrider900 is offline
post #2 of 8 Old 04-25-2009, 08:18 PM
diesel_19's Avatar
yes the tires will fit
E99 f350 cclb 4x4 6speed
4in tb 6in tip
Ts chip
Ccv mod
Diy intake
Epbv delete
diesel_19 is offline
post #3 of 8 Old 04-25-2009, 08:42 PM Thread Starter
Also they are is selling the rims off the F-150. Will they fit a F-350? They are chrome rims.... forgot to mention.
post #4 of 8 Old 04-25-2009, 08:44 PM
fordfan30's Avatar
the tires are probably not load rated for your truck. if you haul anything more than a full tank of fuel you could be putting your saftey at risk.
06 F250 4x4 ecsb, lowered 2", 6 Autometer Phantom 2 guages, Accufab Elbow, Zoodad, Airaid , Magnaflow 4"dp, 5" pipe 7" short stack, Studs, Egr delete, sneaky pipe, regulated fuel return, 6.4 banjo bolts, Moderate FICM from Innovative, High idle and foglight mods, Bilsteins, Sulastic shackles, DIY Harley headlights and traction bars. 8.76 in the 1/8th
fordfan30 is offline
post #5 of 8 Old 04-25-2009, 08:45 PM
bugstroke's Avatar
rims will not fit but u will have no problems with tires if ur rims are 18s
03 Excursion 6.0 Eddie Bauer 4x4...egr delete, sct with custom innovative tunes, blue spring mod, Zoodad mod, 6.4 banjos, 18" Harley wheels. 4" turbo back exhaust with 6in tip, dieselsite coolant filtration system.
studs, 4" lift with 20x12s and 33s, factory 05-07 headlights......all coming sometime when cash flow allows!
bugstroke is offline
post #6 of 8 Old 04-25-2009, 09:16 PM
AFBLUE's Avatar
The straight up answer is no on the tires and no on the wheels.
The only BFG tire I could find is a Rugged Trail T/A in 275/65/18 on their website. they are 114T load rated which is 2365lbs. If you have a Crew Cab Long Bed, thats 8500lbs, 4 adults at 200 each you are already over the load rating of those tires. Those are an SUV tire and have no business being on a 1 ton truck. Also your stock tire size if you have 18s are 275/70/18 so you you would be going from a 33.2" tire to a 32.2" tire.
Onto the rims. Your bolt pattern is 8lug X170mm, F150s are 6 lug. I am sure the F150 also would run a narrower rim, and they probably arent Forged either.
Hope that helps, it would be straight up dangerous to run those tires.
06 CCSB Lariat 102K
Factory 20s w/ Nitto Trail Grappler 35X12.5X20
Vegistroke 75,000 miles
2.5" Readylift Level
ARP Head Studs
EGR delete
Swamps 58V FICM
Isspro Gauges, EGT, Boost, Trans.
20ft of 4" straight pipe!!
SCT X3 BAMF Innovative Xtreme Race
AFBLUE is offline
post #7 of 8 Old 04-25-2009, 09:35 PM
diesel_19's Avatar
tires are tires in my book.if there a good deal get them
4in tb 6in tip
Ts chip
Ccv mod
Diy intake
Epbv delete
post #8 of 8 Old 04-25-2009, 09:38 PM
No point in getting tires when they aren't even an LT tire. If he's putting tires on rated for 2365lbs they are gonna blowout.
2005F250 is offline
