Motor warrantys with a lifted truck, help!!! - Ford Powerstroke Diesel Forum
Old 04-16-2009, 03:22 PM
Lbs Lbs is offline
Have any of you with lifted trucks, mostly 8" or up have any problems with the dealership not wanting to warranty motor work? I have a slight oil leak and im thinking an injector or two are going bad and I need to warranty this soon. My problem is that I have a 8" lift on 38.5's and tomorrow im about to go up to a 10" on 40's unless someone convinces me otherwise. I really need to warranty this but I wont be able to for another week or two. Will they hassel me about it? Has anyone ever got hasseled for motor work on a lifted truck? Thanks in advance
Old 04-16-2009, 03:28 PM
some may have a problem but most wont. i use to bring my trucks to dealers when they were lifted and never had a problem. be sure to take your chip or programmer off before you go in tho.
Old 04-16-2009, 03:29 PM
ya they cant say much. Its no worse then towing a snowmobile to two all the time LOL
Old 04-16-2009, 11:46 PM
When I still had warranty, had no issues getting engine work covered at all. I'm on 40s w/ 10" lift
Old 04-17-2009, 08:57 AM
Lbs Lbs is offline
Thanks very much everyone! DryHeatDude03, can you post some pics of your truck please?
Old 04-17-2009, 01:06 PM
The only problem I have run into was when my power steering box went out, and I can't really complain about them not covering that.
Old 04-19-2009, 08:33 PM
NP Bro,,Here's a few,,,
Old 04-19-2009, 08:38 PM
A lot of dealers don't like working on lifted trucks because it's a total pain in the azz to work on them when they are that high. All the time I'll see them take the wheel's off and then lower the truck to were the rotors are an inch off the ground. Would you like to pull an engine out of a lifted truck on 40's?
Old 04-20-2009, 10:02 AM
Lbs Lbs is offline
Agreed ^ Thats why I was concerned, I'd like them to be comfortable working on my truck then be in a bad mood while doing it. Things dont go well in that situation.
Old 04-20-2009, 10:03 AM
Lbs Lbs is offline
And thanks for the pics DryHeatDude03, very nice!
