4x4 Question??? - Ford Powerstroke Diesel Forum
Old 04-14-2009, 07:10 AM
4x4 Question???
When i turn the 4x4 knob to 4x4 high the little light on the dash that says "4x4" comes on. but if i switch it to "4x4 low" it dosnt come on at all. wtf? any ideas?
Old 04-14-2009, 07:14 AM
COLLEGE KID
Send a message via AIM to lifewitlooie
If it still works who cares lol Maybe the build behind the "Low" light is out.
Old 04-14-2009, 07:19 AM
are you going into neutral when you go into 4 wheel low...
Old 04-14-2009, 07:20 AM
thats what im curious about. does it still work is my question?
Old 04-14-2009, 07:21 AM
oh yeah i always go into neutral to change in to 4x4
Old 04-14-2009, 07:22 AM
ill be at a dead stop, put it in neutral, switch to 4 wheel high, and the light comes on. turn it one more click to 4 wheel low and it goes off.
Old 04-14-2009, 07:26 AM
hmm....well for one you dont need to go to neutral to go to 4 wheel high......just switch it and it will go ...you can switch going up to 55 mph to 4 wheel high .....as for 4 wheel low you do need to go to neutral .......so my other question is .....is your trans going into low gears in 4 wheel low even though the light doesnt come on
Old 04-14-2009, 07:29 AM
Send a message via AIM to jhaddox
if its in 4 low you will know...its geared down low with a ton of torque...you shouldnt be goin fast in 4 low at all..just put it in 4 in gear...drive for a second forward...switch to nutral put it in 4 low and back to drive see if you notice a difference..you should
Old 04-14-2009, 07:41 AM
its at the dealer getting head studs and a new turbo right now. ill try it when i get it back. another question i had was when i do a boosted launch my front tires spin as soon as i let off the brake and my rears just follow suit and dont spin at all. im trying to get all of this bs figured out before i go to the track on the 25th.
Old 04-14-2009, 11:56 AM
The manual gives a very indepth understanding procedure on the 4X4 switch.
