SCT, Tire Size & Speedo Adjustments?
There is a place for Tire size selection in the SCT. If you enter other than stock does the computer make adjustments to the speedometer for the difference in diameter?
It just adjusts the tire size for shifting. Doesnt do anything for the speedo
I thought so, but I wasn't sure
Really? I thought for sure it adjusted the speedo. How do you do that?
You need a "truspeed" (I think thats what its called) to adjust the speedo
You need a superlift truspeed, Auto engineuity, The TS Respeed. Or ford can flash it for up to 35s
) they could not (or would not) guarantee the accuracy. Nor would they reflash till it was correct without charging for any subsequent reflashes. So be aware of that.
Is it only the X3 that has the tire size adjustment option? I have the Xcal2 and haven't seen that option. Can it be written into the tune?? I know on DJ's tunes I can adjust my shift points but on erics I can not.
Use this tire calculator to figure your revs per mile Tire Size Calculator |
