TBC reading TBC fault at random - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-10-2009, 09:42 PM Thread Starter
RamAirfreak98ss's Avatar
Quoted: 4 Post(s)
Garage
I dont know whats causing it.
I first noticed when i had a trailer hooked up, the TBC never shows a "red" trailer icon, but the dash reads "trailler disconnected" or TBC fault while towing, but the trailer brakes always work, so do the lights :/
I then realized it does this on 2 trailers...
Then when NOT trailering, the truck reads trailer disconnected and tbc fault sometimes at random.
Im thinking its a short in the wiring?
The preivous owner had a company install a gooseneck hitch AND 2nd put in INSIDE the left side of the bed. Both apparently work, are chean, dirt free etc.
Would this be caused by the 2nd adapter for the gooseneck plugs or is it something else?
04 F350 XL
06 F350 Lariat SRW BPD oil cooler, ARP, sinister !egr, s&b intake
06 F350 Lariat C/C DRW 4" Silverline , BPD egr cooler, ARP studs, Garett powermax turbo
07 F550 XL c/c 12' ABC american landscaper
11 F350 Lariat C/C !dpf/doc, SCT 7015
14 F550 Lariat C/C Dump truck, !def/dpf, Flo-Pro, T1 Tuner, S&B intake 3200miles
16 F350 Lariat c/c Nov 2015
RamAirfreak98ss is offline
post #2 of 10 Old 04-12-2009, 06:04 AM Thread Starter
Quoted: 4 Post(s)
Garage
no one?
04 F350 XL
post #3 of 10 Old 04-12-2009, 12:57 PM
muddy650's Avatar
Mine does it when I hook up a trailer that has the big round plug, but only four of the wires are used. The trailer needs a 4 wire flat plug, but somebody put the big one on and just didnt use the other wires. If it is like mine, the truck thinks there is a trailer with brakes back there because something is plugged into it and something is wrong because they ain't working. May not be what is wrong with yours, but hope thuis helps.
Mine will show TBC on dash if I carnk it in neutral , instead of park, with a tune on it also. I have no idea why it does that, But everything seems fine!
2004 F250 CC SB
SCT Xcal2 SPD+ Lonney Wild Track
ARP Studs
PHP FICM Tuner
2003 Turbo
Coolant Filter
EGR Delete
4" Magnaflow
Airaid Intake
Zoodad
Blue Spring
6.4 Banjo's
CAT EC-1
Custom Camo Seat covers
muddy650 is offline
post #4 of 10 Old 04-12-2009, 01:00 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Its usually one of two things. A loose connection. Or a faulty brake master cylinder
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #5 of 10 Old 04-12-2009, 04:29 PM Thread Starter
Quoted: 4 Post(s)
Garage
well hope its a loose connection lol. I think it beeps like "low fuel" sound when you hit some little bumps in the highway, thats normally when it says tbc fault or something. but sometimes its beeping over and over , a few times in less than a minute, so its annoying at the very least.
I dont want anyone else driving it until thats fixed for safety sake.
04 F350 XL
post #6 of 10 Old 04-13-2009, 07:44 PM
They all throw that fault when the voltage at crank is just a little low. Mine did it all the time before I changed the batts. My cousin's 05 and my friend's 06 dually did it too right before the batts took a dump. I'd check that first and then start looking for loose/shorting wires or a screwy master cylinder.
2006 F-250 Powerstroke Crew Cab Lariat Long Bed 4x4 FX4
SCT Xcal2 with Xtreme tunes by Innovative
Banks Monster Exhaust/Quadzilla Commander
ARP Head Studs and Elite Sneaky Pipe (Thanks Scuffy)
tech10002 is offline
post #7 of 10 Old 05-07-2009, 11:20 AM Thread Starter
Quoted: 4 Post(s)
Garage
well truck went into the dealer today... theyre saying after a $125.00+ tax diagnostics that the Brake control module is bad and needs to be replaced..
They want $125 diagnostics, $350ish for the control module and i guess the rest is labor to install it.
Where is this part and seriously, how hard can it be to replace? ive rebuilt whole engines and parts of transmissions on GM cars in the past so im pretty mechanically inclined.. Is that part really that much?
04 F350 XL
post #8 of 10 Old 05-07-2009, 11:29 AM
Chapter Director
psd_va's Avatar
controll modules are not cheap so i wouldnt doubt it but it should be that hard to replace yourself but i don't know if it will need to be programed.
psd_va is offline
post #9 of 10 Old 05-07-2009, 05:35 PM Thread Starter
Quoted: 4 Post(s)
Garage
well maybe i dont know as much about it as i thought. You cannot just buy one off ebay/craigslist/junkyard and disconnect your stock "broken" one, and connect the new one, what is it programmed for? The truck already has one so its a direct swap out.
04 F350 XL
post #10 of 10 Old 05-08-2009, 03:46 AM
Chapter Director
psd_va's Avatar
The module itself might have to be programmed not the whole truck but I'm not sure it might be plug and play
03 F350 6.0 SRW 4X4 lariat
481hp 832tq
8" super lift 385/70r16 Toyo MT's
FatBoy traction bars
Durastroke stg1
intake
MBRP 5" straight pipe
Custom tuned by Vivian "Looney Wild Track"
Edge Insight CTS
Zoodad mod
high idle mod
6.4 banjo bolts
Updated fuel pressure regulator (Blue spring mod)
EGR cooler delete
6K 55w HID's
6k 35w fog HID's
B&W turnover ball
psd_va is offline
