Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > General 6.0L Discussion
Old 04-10-2009, 09:55 AM
3pedal 3pedal is offline
What should I see on the boost guage?
My truck and I are still getting it know each other. So far, I am very pleased with it.
From what I can tell, it is stock. I have never seen the (stock) boost guage go over 20 PSI, in fact, it may not have hit it. What should I be seeing? I see a lot of you guys talking about much higher numbers, but assume that is with a tuner.
I think the truck sat at the dealer for a few months, and I understand that should be avoided if possible.
Old 04-10-2009, 10:00 AM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
that is normal on a stock truck... you wont really see much more until you get a tuner..
Old 04-10-2009, 10:10 AM
Cool.
A tuner is down the list a ways for me.
After I figure out how emissions work here, I think exhaust will be the first thing I do.
Old 04-10-2009, 10:15 AM
more than likely they just want you to have a cat to pass emsissions... you can get a kit like MBRP that retains the factory cat and get their cat "test" pipe to remove it when you dont have to pass emissions....
-Raul
Old 04-10-2009, 12:17 PM
Are there O2 sensors to mess with if you "test" without the cat?
Old 04-10-2009, 12:33 PM
Miller_Time Miller_Time is offline
20 PSI is normal???? I have seen as high as 30 psi on my truck before and as far as I know its 100% stock except for the 4" turbo back exhaust. Does this sound way too high for stock?
Old 04-10-2009, 12:56 PM
Lubbockguy1979 Lubbockguy1979 is offline
Send a message via Yahoo to Lubbockguy1979
O2 sensors are on gassers currently.... Government can't seem to get them on diesels but they are trying lol
Old 04-10-2009, 01:24 PM
03f250stroke 03f250stroke is offline
20 is about right..with the programmer expect to see upper 20 low 30s
Old 04-10-2009, 01:33 PM
yup its normal... anything above 24psi ish and he has some kind of tuner or the gauge is off....
Old 04-10-2009, 01:59 PM
Lbs Lbs is online now
With my truck pegged out I hit about 27-28 (im on 38.5's btw). I have no mods whatsoever besides cutting the muffler off.
