MPG's with lift and big tires - Ford Powerstroke Diesel Forum
Old 04-10-2009, 05:32 AM
I was wondering what MPG's everyone else who has a lifted 6.0 is getting. I just checked mine for the first time since getting the lift and the 38.5 tires and was surprised to find I'm getting 14.5 mpg city, hand calculated. considering I was only getting around 16 before the lift I didn't think 14.5 was too bad. this is the truck -- '07 6.0 250 SD excab, auto w/ 10,000 miles, no performance upgrades except 4' turbo back with the cat reinstalled but no muffler. I am running 55 psi in tires. how I calculated -- since the speedo is off with the big tires I had to do a bit more calculating than normal. when the speedo shows I'm doing 60 I am actually doing about 66, wich is 10% more. when I pulled up to fill up my trip read 167 miles so I added 10% which gave me about 184 actual miles. divided by 12.5 gallons = about 14.5 mpg. how much do you guys feel I could improve upon this by getting a programmer and an intake or any other performance upgrades?
Old 04-10-2009, 05:47 AM
MPG
I'm only getting about 13 or 14 with my truck right now. I have 4" lift on 35's. My speedometer is about 5 mph off so I haven't figured out what the difference might be. I have the Banks Six-Gun w/ PDA and it doesn't help out to much on the gas mileage. Other tuners might more than the Banks. If I put it on the lowest setting and go easy on it, 15 max. On a full tank of gas, how many miles are you running with what your gauge says.
Old 04-10-2009, 06:17 AM
sorry, not quite sure I understand your question. if you're asking how many miles I get out of a full tank, I don't know. I never let it get that low before filling up. the computer on the truck reads about 13 mpg, but I don't trust that so I hand calculate.
Old 04-10-2009, 06:21 AM
dude thats a badd azz truck you got. but you may want to invest in some lower gears to keep that daily strain off the tranny. It is critical for longevity. With 38s I would suggest some 4.56gears this would also help you increase your MPG
Old 04-10-2009, 06:44 AM
the only way you can truly hand calculate is to fill it up as far as possible and take a trip that you know the exact mileage to, say it is 200 miles to this point. then fill up as full a you were before hand, and then do your calculations. using the lie-o-meter to hand calculate is probably not giving you an accurate reading.
Old 04-10-2009, 07:57 AM
hey thanks. yeah, I agree on the gearing. do you think 4.56's would be the best gears for the 38.5 tires
Old 04-10-2009, 05:10 PM
I am getting 14.5 (according to the onboard computer) with a 4" BDS lift and 325/60/20 tires.
Old 04-10-2009, 05:59 PM
I just did this today.... I just installed a propane injection I had laying around and got 22 MPG on the highway and 18.4 in the city. Thats with almost a whole tank ran through it. The lie-o-meter said I was only getting 18.6 MPG.
Old 04-10-2009, 07:17 PM
i'm getting about 14 1/2 and that's driven extremely conservative . that's hand calculating & using my gps to calcualt the miles .
Old 04-13-2009, 03:53 PM
pardon my ignorance, but what is a propane injection?
