EGR MISBELIEFS??? - Ford Powerstroke Diesel Forum
Old 04-06-2009, 06:10 PM
EGR MISBELIEFS???
THIS info came from another site just curious what people on this site have to say about it????
Use a prybar or an alignment bar with a 90* bend on one end. take the two 8mm (not 10mm) out of the EGR valve. Rotate the valve slightly, place the 90* end of the bar under one of the mounting tabs. Pry up slightly, and POP! out it comes. Pick it up, and throw it i the trashcan. Call and order a CX-2020 from for an 05 up truck, or a CX-2056 for pre-05 trucks. Ford no longer endorses cleaning the EGR valves, not to mention the fact that it doesn't work.
There ARE hundreds of people that are misunderstood on EGR deletion.
Are you aware, at the bare minimum, that the EGR acts as a boost failsafe for when the turbo sticks?
I am not going to get into the complexities of the EGR/Boost strategies tonight, it's late, but I will put something together for you guys to read.
I will be the first guy to admit the 04-up EGR cooler SUCKS..but I would definately not delete the EGR system on a 6.0
Old 04-06-2009, 06:12 PM
This should be good for a train wreck. I have read for years now how deleting was the only way to go!
Old 04-06-2009, 06:14 PM
kinda the way i was understanding till i read this
Old 04-06-2009, 06:20 PM
Rice Hunter
Interested in seeing more myself. Ford techs are even deleting their own!! Mine seems to do better w/o
Old 04-06-2009, 06:42 PM
does nobody have anything to say about this
Old 04-06-2009, 06:58 PM
I say delete the cooler. Ive seen way to many coolers leaking when they role into the shop.
Old 04-06-2009, 07:03 PM
Old 04-06-2009, 07:10 PM
^^^^????????? did you forget what you were gonna say????
Old 04-06-2009, 07:23 PM
post back to the site you saw it and ask him to elaborate
Old 04-06-2009, 07:25 PM
OP'er, you are saying to leave EGR valve, but delete only the cooler?
Russell
