boost gauge - Ford Powerstroke Diesel Forum
Old 04-04-2009, 09:54 AM
boost gauge
I just installed an autometer GS boost gauge in my 05. When I get on the truck a little the needle is real erratic. I was wondering if this is common or not. I was also told that I may have tightened the nut down to much and smashed the feral.
Old 04-04-2009, 10:29 AM
Illiana Chapter Director
Do you have the gauge tapped into the "MAP" line? If so, remove it from there and tap your intake elbow. That should help.
Old 04-04-2009, 12:50 PM
Location: not to far from the city of "Brotherly Loved"
+1 for the intake elbow..
Old 04-04-2009, 03:34 PM
Id say tap the elbow too just make sure you keep the boost line away from the turbo or it may melt.
Old 04-04-2009, 03:51 PM
your boost guage should have a smooth "sweep"
[IMG][/IMG]
Old 04-04-2009, 03:56 PM
+1 for the elbow!
Old 04-04-2009, 03:59 PM
Is that just relevent to the 6.0's or should i drill and tap my intake? Right now im slpiced into the MAP sensor however, im not having any problems with my gauge. Does it give a more accurate reading or something
Old 04-04-2009, 04:01 PM
The gauge will go up and down more smoothly and some say its a more accurate reading.
Old 04-04-2009, 04:02 PM
It's suppose to be more accurate in the elbow. You don't always have gauge flutter or the rattle noise when you tap into the MAP sensor but my 95 did.
Old 04-04-2009, 07:19 PM
Maybe I will wait a little bit and get an aftermarket elbow with the pre taped ports. It won’t wreck the gauge will it? It is rather annoying though, especially at night lol.
