Help a Guy Decide - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-04-2009, 08:10 AM Thread Starter
SASKFORD's Avatar
Help a Guy Decide
I have a 2006 PSD Super Cab 4X4 with 3.73 gears. I am running factory tires and rims but want to step up to a lager tire size. I have bought Mickey Thompson Classic II's (17X9) and want to wrap them with 35's. I belive that I will need at least a levelling kit to do this as the rims are going to stick out an extra 2.5" from where they sit now. Here are my questions:
1. Will 35's fit with no levelling kit?
2. With 3.73 gears will I notice a big change in power? I pull an 8,000lb travel trailer and a 1000lbs of gear in the box of the truck.
If you have a similar set up please attach some pics to your reply.
Thanks
SASKFORD is offline
post #2 of 8 Old 04-04-2009, 08:35 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 30 Post(s)
Feedback Score: 4 reviews
The problem your going to have is getting those rims to fit. The 05-07 brake rotors are bigger than the previous 03-04 truck. But to answer your questions, I think your going to need the 2.5" leveling kit to use the 35's. I'm not sure how they will affect your towing abilities though. I know when I went to bigger tires on my old 150, I did notice a difference, but not much. I only went up a couple inches in height, but the width is where the extra weight came from.
My truck with a 2.5" leveling kit from Tuff country, with stock tires
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #3 of 8 Old 04-04-2009, 09:03 AM Thread Starter
SASKFORD's Avatar
Why would I have any trouble fitting the Mickey Thompson rims?? I am going from a 17X7.5 to a 17X9 with less offset. I don't see an issue with that. My main concern is loss of power going up 3 inches on tire size.
SASKFORD is offline
post #4 of 8 Old 04-04-2009, 09:12 AM
I am with the other guy. those rims may be to small. I just looked at mine and i have 18x9 4.75 backspacing and have about 1/2" of clearance between caliber and rim. I would test fit a rim on the front and make sure before going any further. I you are worried about the lose in power better just stick with want you all ready have.
Stroking the oilfield is offline
post #5 of 8 Old 04-04-2009, 09:13 AM
2006PSDSD's Avatar
Quoted: 30 Post(s)
I have heard from a lot of people that 17's won't fit on the newer trucks . That's all I had to go on. My rims are 18's on my 350. That's cool that I may be able to use 17's, cause the tires are cheap, and so are the rims.
I'm not sure that going to 35's on a powerstroke is going to affect the towing very much, you may not even notice the change in gearing
Post up pics when you get her finished up
I had a friend that put 35's on his truck, with the same gearing as you, and he never complained about towing his 10k 5er. His is a 6spd though, so that will make a difference
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #6 of 8 Old 04-04-2009, 09:15 AM
2006PSDSD's Avatar
Quoted: 30 Post(s)
He is taking off his 17's and putting the same size back on, as long as the back spacing is correct. I was under the same impression you are about them having to be at least 18's. Maybe my wheels are bigger because I have a 350 instead of a 250
2006 F350 SOLD
* 08 style mirrors
* 4" TB exhaust
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Stage1 MTW turbo
post #7 of 8 Old 04-04-2009, 01:05 PM Thread Starter
SASKFORD's Avatar
The truck has factory 17's and will be replaced with 17's. There is no problem with the rims here guys, the problem is the tire size and the gearing!!
SASKFORD is offline
post #8 of 8 Old 04-04-2009, 01:31 PM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
I think that you will be fine going with the 35's. When I was running 35's I had no trouble towing!
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
