Idea's on where to mount a Pyro???
I decided my stock tranny temp and boost gauge are sufficient but want a pyro. I also like my grab handle and don't want to lose it. If I mount the gauge on my steering column it will block the boost gauge. I can't mount it above the mirror because I have the power sunroof controlls and map lights. I was thinking of mounting this to the lower part of the grab handle:
Auto Meter 48000 - Auto Meter Gauge Mounting Cups |
they make a single gauge pod that mounts under the grab bar, so you can still retain it..that would probably be the best option, unless you go with a single steerting wheel pod..those are nice too.
Auto Meter 15318 - Auto Meter 2-1/16'' Single Gauge Pods - 2003-06 F-Series Super-Duty Truck |
Honestly the stock trans temp is totally worthless, but anyway do you have eletronic shift 4x4? I put my pyro right in that spot. I can get ya a pick if you want.
Thanks Adam, I was wondering if that would fit.
DieselDan, I have the electronic 4x4 switch. |
I have seen some pods that mount under the a/c controls, as well as mounting over the factory instrument bezel.
Ford Gauge Pods & Mounts for Ford Trucks Hope this helps. |
I had a single pod mounted under the grab handle for awhile before i got the triple set-up. They sell them on eBay for like $10 +shipping.
