Degas Bottle?
I just bought this truck maybe a month ago and ive read that 03-04 are notorious for blowing head gaskets. I have topped off my coolant maybe two times. Its not puking out the cap or anything and it doesnt over heat and its not empty. The truck has 74k on it. Anyone got any ideas?
When are you topping it of? It will only show its full or normal when the engine is cold
We had a couple of 6.0L at work that would loose coolant all the time and we couldnt figure out where it was going.
We took them into Ford and they told us that the head bolts were stretched and everytime it boosted up the heads would actually lift off the motor and the coolant would leak out that way. I dont have any idea if this is true or not but thats what we were told by Ford. |
Mine was the oil cooler it was plugged and not allowing coolant to pass. I knoticed no gauge +ver heating but could hear the cluth fan engauging like it was hot or if maybe it was a 90* day. It was 60-70 out side... They drove it and I guess datalogged it found out the engine oil temp was a lot higher than the coolant temp replaced the oil cooler and I haven't had a lost coolant issue in almost 8 months been running tunes and still no issues. I would look at the oil cooler and keep it topped off on coolant. Also untill I explained eactly what it was doing they were just cleaning the egr which did nothing
I checked the coolant before I started my truck this morning. It was a little low. I wanna do head gaskets and studs but thats probably gonna cost a pretty penny.
Your EGR cooler is probably in the early stage's of breaking. Do you smell coolant in the cab when the fan clutch turns on? If yes, then your EGR cooler is probably busted.
Actually, Clay, that is a problem with these engines. International uses Torque To Yield (TTY) bolts on the heads, and they are known to stretch, when running hot, which could cause this problem. Is that his problem? Who's to say, until a mech looks at it, but it is one of several valid solutions to his problem.
