looking for suggestions - Ford Powerstroke Diesel Forum
post #1 of 5 Old 02-06-2009, 04:55 PM Thread Starter
I've just finished a oil cooler replacement and egr cooler delete. The cooling system is completely full of oil and antifreeze mixed. Just wondering what some of fellows that have had the same problem used to clean your cooling system. Dish washing liquid [dawn] has been suggested to me. Just wondering if yall might have something that yall used that may work better. Thanks.
forrestgump is offline
post #2 of 5 Old 02-06-2009, 05:01 PM
Quoted: 23 Post(s)
Unhappy
Ford recommends using dishwashing detergent - liquid Cascade or Sunlight (for low sudsing), unless there is too much oil contamination.
From a tech :
well we use commercial degreaser at work. it encapsulates the grease and gets it out pretty quick. but you will never get it all out. i have had some i have flushed for hours, and they come back oily again. gold coolant loves mixing with oil !!!
From a tech :
I've used chemical flushes, simple green and liquid dish detergent (sunlight). I find the dish detergent works best, followed by the simple green, and the chemical flushes might as well just be poured in the trash IMO. I prefer to remove and send the radiator to be flushed, and I'll replace any rubber hose that's gone bad, as well as the degas bottle cap. I normally flush them about 4 or 5 times, depending on the degree of failure.
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #3 of 5 Old 02-06-2009, 05:07 PM Thread Starter
Bismic, I had thought about using the degreaser but wasn't sure if it would do any damage to the rubber in the system.
post #4 of 5 Old 02-06-2009, 05:22 PM
Quoted: 23 Post(s)
Personally I would go with the low suds dishwashing detergents. That is the most common choice from the posts I have read. If the contamination is real bad and the dishwashing detergent does not seem to be doing the job - you may have no other choice but to use the degreaser. Still - I would give the detergent 4-5 trys first.
Mark
bismic is offline
post #5 of 5 Old 02-06-2009, 05:38 PM Thread Starter
Thanks for the advice bismic. Think I'll try it in that order.
