Want to make sure I'm in right direction
Well, thanks to all so far in giving me ideas and advice as I am looking to get my first PSD. In reading some of the threads and answers to my questions I still have a couple more questions to ask. I want to make sure I hit the ground running when I get my truck. I'd rather save up a few more $$$ to make sure I get it done right the first time.
This is what I am looking at getting right off the bat: FCDP egr delete, sctx3 with tunes nothing to radical, 4" tb exhaust no kitty, amsoil filter bypass kit. My feelings is the EGR system on these is sub-par and I am not going to subject myself to aggrivation from hoping it does not fail when I need the truck the most. What I would like to know is should I be concerned with the engine oil cooler. Adam from FCDP mentioned in a email depending on the mileage I should either replace the oil cooler or test it? How much of a concern is there with this? I would like to not have issues as possible. What else am I looking at to do for starters, and no the studs will not be on there yet. I know the warranty might be an issue, but the dealer that I am a vendor for says as long as it does not look abused in driving it they would take care of me, after the fact I stated the weakness of the EGR system. Sorry for the long post, I am trying to make sure I have enough $$ before i go in with both feet.- |
I was reading not the EGR itself, but the cooler to be the host of many problems, I'd rather bypass the whold inadequate(sp?) system than take my chances with the egr cooler. What is wrong with amsoil? I have been using it for quite some time.
a buddy of mine just bought a new engine for his 06 because he was using extended life amsoil.
Oh no...here we go again. There are a lot of mixed feelings here about different oils. Use whatever works for you. If you want to know more you can search through the several threads already started on that very subject. I wouldn't open that can of worms here because the thread will be derailed in about 10 seconds
too late.....![]() BTW welcome to the org! |
Your EGR cooler can't fail i don't believe if the EGR valve never opens.
From what I saw from that GA powerstroke repair facilty on the video, he highly recomends the amsoil bypass add on filter system, or any filter bypass system add on for that matter. I can get the Amsoil one cheaper through work, that is why I mentioned it. If I am in the engine that far for the EGR why not delete everything and no worries, l'd rather have peace of mind.
I have heard of this problem with all the 6.0L diesels. Most guys want to cap off the EGR. I heard about these guys in Phoeinx that make an upgrade kit - it uses the standard original outside of the cooler but the inside is removed (the radiator looking stuff) and in its place a new, welded, all-stainless steel body thats 1000 times better than what Ford has put us through.. check it out.
